TRUCK WONT START NEW HEADS
Old Mar 19, 2010 | 08:26 PM
spokes's Avatar
Default TRUCK WONT START NEW HEADS
Finished getting the truck back together today after putting new heads and studs. All lights and gauges work but when you hit the key to start the starter will not crank. Its not the starter because i went under the truck to cross the starter and it cranked over 100% but would not start. Any ideas or things to check?
Old Mar 19, 2010 | 09:02 PM
Codes? Bleed the fuel system?
Old Mar 19, 2010 | 09:41 PM
spokes's Avatar
It just wont crank with the key.
Old Mar 20, 2010 | 09:32 AM
Mdub707's Avatar
Double check all of your electrical connections. Make sure you have a good ground.
Old Mar 22, 2010 | 12:46 PM
spokes's Avatar
Found the problem. Never had the positive wire conected by the heater motor. Now got the truck to crank but it wont start. Have oil presure on the gauge and have just under half a tank of fuel. Now what the %@$# could it be?
Old Mar 23, 2010 | 08:07 AM
Diesel Powered Rocket's Avatar
Can you hear the fuel pump run with the key on and engine off? If yes.
Did the fuel bowl / filter fill up? If yes.
Do you have a raw fuel cloud huffing out the exhaust? If No.
Start checking all of your electrical connections. Check for engine codes. Are you using the same FICM?
doublehbar
13
Aug 9, 2015 12:35 AM
doublehbar
33
Jun 5, 2015 11:38 AM
dfish001
Mar 30, 2015 03:07 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
ronstop
Feb 26, 2015 09:48 AM
