Heater problems
Old Mar 19, 2010 | 01:41 PM
TTipsword's Avatar
Default Heater problems
Well last night in a snow storm my heater decided to start giving me trouble. I can hear the blower working under the dash but hardley get any air coming out of the vents. when this happened the heater is now louder than it was. any ideas?
Old Mar 19, 2010 | 01:53 PM
Begle1's Avatar
No air coming out of any vents?
Try switching to recirc, maybe your front vent is clogged.
You have a vacuum-actuated valve on the heater core that should default to "open" and only close when you turn on A/C, you have the red-to-blue blend-door slider that is a mechanical linkage with the blend door, then you have three vacuum actuators; one opens the defroster vents, one selects between floor vents and dash vents, and one selects between recirculator door inlet and front fresh-air inlet. (The defrost actuator is only relevant if the dash vents are closed.)
Something's probably stuck.
Old Mar 20, 2010 | 01:35 PM
TTipsword's Avatar
well how do i get the deal un-stuck?
Old Mar 20, 2010 | 10:02 PM
Begle1's Avatar
They might accumulate grit and grim on the pushrod that comes out of the actuator, and that might hang things up.
Probably more likely is that a plastic vacuum line broke or got kinked, although they seem to me like they're pretty high quality.
Worse comes to worse get a new actuator. They're pretty easy to find and cheap in junk yards. Might even be able to rebuild one...
kelchy82
6.2L & 6.5L Performance
10
Nov 27, 2016 04:32 PM
ramrunner01
Feb 25, 2015 11:14 PM
Mike H
Jan 25, 2015 10:08 AM
bikernut
Audio Equipment/Electrical
Dec 18, 2014 03:30 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
