drill bit and tap for pyro in manifold
Old Mar 19, 2010 | 12:12 AM
bowtech's Avatar
Default drill bit and tap for pyro in manifold
mine is post turbo and going to move it is it a 1/8 bit and tap both the 1/8 size or what?
Old Mar 19, 2010 | 12:15 AM
12valvetater's Avatar
1/8 in pipe thread is a size R drill bit. I used to know the size in inches but I forget now.
Old Mar 19, 2010 | 12:39 AM
ArizonaRedneck's Avatar
the size is a 11/32 drill bit
Old Mar 19, 2010 | 12:58 AM
Technically you should use a size R as 11/32 is not exactly there, but it's close enough
Old Mar 19, 2010 | 01:15 AM
the size R is just a tad bit smaller right
Old Mar 19, 2010 | 05:31 AM
glfredrick's Avatar
.325"-.343" -- because of the taper, there is some leeway in drill size. I've seen everything from Q to R to 21/64" to 11/32" mentioned. As you go up in size the threads will be less tight and you'll have to turn the fitting deeper into the hole to seal it.
http://www.carbidedepot.com/formulas-tap-pipe.htm
Here is a chart that lists all the drill sizes in decimals:
http://www.auto-ware.com/techref/drillsizes.htm
Old Mar 19, 2010 | 06:32 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
21/64 some guys use 5/16.
Old Mar 19, 2010 | 10:46 PM
bowtech's Avatar
so one of those bits then the 1/8 tap?
Old Mar 19, 2010 | 11:20 PM
yes, 1/8" NPT.
And this is very important - dont run the tap in too far (3/4 of the tap maximum) if you go past that your fitting will be loose in the manifold and you dont want that.
Old Mar 20, 2010 | 01:24 AM
bowtech's Avatar
whys that the tap shaped like a cone??
