PULLING THE TRANNY!
Old Mar 18, 2010 | 09:13 PM
redwood logger's Avatar
Default PULLING THE TRANNY!
It has been about 15 years since i have pulled a autamatic tranny and this is my first time ever on a dodge. my question is do you un bolt the torque converter from the flywheel before you un bolt the tranny from the block or does the torq stay on the flywheel as the tranny is pulled away?
Old Mar 18, 2010 | 09:16 PM
DieselPerformanceGuy's Avatar
I'm pretty sure it stays either on the tranny or the flywheel either way i'm almost certain that there is no unbolting.
Old Mar 18, 2010 | 09:28 PM
tltruckparts's Avatar
you need to unbolt it before you pull the transmission. should be 6 bolts i believe theyre 15mm. if you try and pull the trans without taking it out first, you can mess up the input shaft of the transmission. and when you unbolt it, make sure you push it as far into the transmission as you can before pulling it. if you pull the starter, you can turn the engine by hand until you have access to the torque converter bolts through the starter hole
Old Mar 18, 2010 | 09:38 PM
I guess my real question is how do i get the torq off the flex plate when i try to un bolt it the bolts come out until they hit the plate between the flex plate and the motor. my goal here is to replace my rear main seal
thanks tlttruckparts thats the info i needed
Last edited by redwood logger; Mar 18, 2010 at 09:38 PM. Reason: Automerged Doublepost
Old Mar 18, 2010 | 09:58 PM
glad i could help
Old Mar 18, 2010 | 10:51 PM
Begle1's Avatar
There's an inspection cover on the right-side of the engine that you can pull the converter bolts off of... I've never took them out of the starter hole before.
Old Mar 18, 2010 | 10:53 PM
that works too. lucky for me someone before me torched out a slot in the adapter plate so i could do it just like a chevy right through the bottom
Old Mar 19, 2010 | 09:01 AM
RSWORDS's Avatar
x2
I un did mine through teh instection plate on teh bottom though.
Old Mar 20, 2010 | 09:44 AM
well the inspection hole on the passenger side seemed to be the only possible way to get the flex plate bolts out, worked great!
wilki
Feb 12, 2015 09:04 AM
Ol Goat
Jan 22, 2015 02:16 AM
B.k. Smith
10
Jan 7, 2015 02:29 PM
Ol' RED!
Dec 11, 2014 10:00 AM
Trevlar11
Nov 16, 2014 01:59 PM
