surging boost
Old Mar 18, 2010 | 06:02 PM
crazycooter's Avatar
Default surging boost
After about 30 minutes of drive time, I start to have surging boost, where it will go from 10 - 15 lbs down to 4-5, and then if I step into a little harder, it will pop right back up to where it was. I suspect that I may have an exhaust leak or something and think maybe the manifold gets hot enough after a while to leak at the turbo. This is simply my best guess. Any suggestions?
BTW, what is this adjustable boost elbow that everyone keeps talking about, where does it go and what does it do?
Old Mar 18, 2010 | 09:22 PM
mainman300's Avatar
what are your rpms doing when you are loosing boost?
Old Mar 19, 2010 | 09:33 PM
2500ho2's Avatar
thats also a symptom of apps going bad, are you getting code , if not then is more than likely that. had exact same problem and was apps
Old Mar 20, 2010 | 11:08 AM
Not going to fix you problem - check for codes.
The boost elbow allows your turbo to build more boost (output obviously) before the wastegate opens. And its more desirable (in my mind anyway) than disabling the wastegate.
Old Mar 24, 2010 | 02:45 AM
no codes, I have another apps at home, from chasing earlier problems that turned out to indeed be the vp44 and injectors, maybe in a couple of weeks, I will try swapping that apps back to the old one. Shouldn't the apps spark a code too? like 0121?
Old Mar 27, 2010 | 01:23 PM
Blackout_CTD's Avatar
could be the boost sensor mine did the same thing. on rough roads it would fluctuate and on smooth roads i had no boost
bought the boost (map) sensor from the local stealership for $98 bucks
stewart.william.c
Feb 11, 2015 01:39 AM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
joshkhouse80
Nov 21, 2014 01:17 AM
