wont start when hot
Old Mar 17, 2010 | 09:07 PM
riddick01's Avatar
Default wont start when hot
ok...so im not the most diesel savy person out there but ive got an 06 250 with a 6.0 and it will start fine when cold(the typical cold start) but after running it for a little bit (to the gas station for coffee) it wont start back up...but if i let it sit and cool down for a bit then it will start ok...i had advanced auto parts check the alternator and its good...the batteries are no more than a few days old...
i think it might by a high pressure oil pump problem or something that is not working at temp
Old Mar 18, 2010 | 08:13 AM
MUDSTROKIN''s Avatar
i'd say you most likely have a HPOP problem....
Old Mar 18, 2010 | 11:17 AM
riddick01's Avatar
thats what i thought to but i figured id post up here to see if anyone had any other ideas since i just put a new HPOP in a couple weeks before xmas...
i ran it to the dealership this mornin and thats what they think it is to so my next question is where do i look or who do i talk to about getting an aftermarket HPOP...this is the 3rd one if had and im only at 95K miles so i want to be able to eliminate this problem...
Old Mar 18, 2010 | 01:58 PM
Hmmmm... dieselsite.com has upgraded HPOP i believe. you might wanna have the tech check out your whole high pressure oil system... i've heard of the standpipes having a problem with them too and causing these same symtoms... or it could be a problem in your High pressure oil rail too... just have the tech check out the whole system! hope this helps!
Old Mar 19, 2010 | 12:07 AM
Mdub707's Avatar
There is a service bulletin for the STC (snap to connect) fitting. That is most likely the issue, it is very common.
Diesel Technician Society
2005 Update Page 04 Turbo High Pressure pump/Discharge tube-Oil Branch Tube-IPR Valve
Old Mar 19, 2010 | 10:09 AM
^ very true i didn't even think of that... thanks for throwin that in there mdub!
Old Mar 23, 2010 | 04:34 PM
riddick01's Avatar
ok so called ford and they say that it is the HPOP and that since this is my third one in under 100k and my second since a couple weeks before xmas they r replacing the pump, housing, seals, and some other stuff to make sure its all good
Accubuck
May 7, 2015 04:46 PM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Feb 22, 2015 09:07 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
powerstroke74
8
Oct 29, 2014 05:40 PM
