coolant leak
Old Mar 17, 2010 | 07:57 PM
redwood logger's Avatar
Default coolant leak
while changing my rear main seal i noticed coolant dripping off the front of the oil pan. the hoses are fine. could this coming from anywhere other than the water pump? there are no visible leaks looking down from the top of the motor. is there anything under the water pump that could be leaking?
Old Mar 17, 2010 | 08:11 PM
Billy D's Avatar
Could it be that back 90 degree 5/8 hose off the back of the canister on the pass side, there are 4 of them 90 degree bastards on the 1st gens, not to mention the little shitty 2-3" pieces. I just changed all mine.
Old Mar 17, 2010 | 08:21 PM
ArizonaRedneck's Avatar
waterpump weep hole could be leaking on the bottom of your waterpump a sign that you will need to change your waterpump
Old Mar 17, 2010 | 08:44 PM
sounds like it might be time to fix my KDP while i am possibly replacing the water pump.
Old Mar 18, 2010 | 01:35 AM
TXHC's Avatar
Also, check the block heater port on the side of the block. The bolt broke on mine, was an easy fix though.
Old Mar 18, 2010 | 08:50 AM
big bad diesel 416's Avatar
Site Sponsor
freeze plug?
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
throttleup22
May 2, 2015 02:04 PM
Mike0885
Feb 28, 2015 03:16 PM
merdth6
Nov 20, 2014 08:01 PM
dieseldummy
6.2L & 6.5L Performance
Oct 1, 2014 07:51 AM
