Holset H2E
Old Mar 17, 2010 | 04:07 PM
PhilipR's Avatar
Default Holset H2E
I have a brand new Holset H2E. I listed it in the For Sale section but I wanted to pick the brains of some of you. It's a 63/71/19. With the mods in my sig is this thing going to be really bad on my truck or can I tune it a bit and get some SDX sticks and DV's and make it work to get to my 500hp DD goal?
Old Mar 17, 2010 | 08:57 PM
dan33klein's Avatar
if your running it as a single charger id have to say it would be pretty laggy.
most people that run a 64/71 charger or in that area run 14 housings with reasonable spoolup and nice egts. i think the 19 would be slow imo
Old Mar 17, 2010 | 09:23 PM
12valvetater's Avatar
Won't know until you try and you may be able to get a tighter exhaust housing for it. It's worth a try at least. The worst that can happen is it doesn't work.
Old Mar 17, 2010 | 09:36 PM
dan33klein's Avatar
yeah id go tighter exhaust housing before id even put it on there
Old Mar 18, 2010 | 05:53 AM
PhilipR's Avatar
There is a 17cm housing for it.....it's non-waste gated so they are usually bigger.
Old Mar 18, 2010 | 08:25 AM
Hammer's Avatar
You will need a tighter exhaust housing or it will be a lag pig.
Also Note...
The H2E is not known for being a charger that takes a ton of abuse and usually end up breaking the shaft.This was one of the reasons many passed them over when they popped onto the performance scene back in late 99.
Old Mar 18, 2010 | 09:44 AM
PhilipR's Avatar
Found a couple turbo maps....anyone care to explain them?
Old Mar 18, 2010 | 10:45 AM
85_305's Avatar
Being Evaluated
Didn't cummins come stock with holsets? Because my buddies '96 sc lb 5spd cummins has a holset on it..
Is the hx35 a holset? And the wh1c?
Old Mar 18, 2010 | 10:50 AM
12vcummins96's Avatar
it will be laggy but with a 17cm it will be ok
Old Mar 18, 2010 | 10:54 AM
PhilipR's Avatar
Cummins owns Holset and Holset is the brand.....
If I can't sell it I might look for a 17cm housing....
