Diesel Dawgs Performance Visit - Diesel Dawgs Performance
Draw Straws
Old Mar 16, 2010 | 11:16 PM
FormerVendor
Default Draw Straws
Draw Straw I
CNC machined billet DSI with dual return ports allows the user to install a regulated return fuel system without drilling the top of the module or cutting the filler neck tube for the second return, makes for a super clean and secure installation and brings all the return fuel back into the module for replenishment during low fuel situations.
The Draw Straw™ I can be used in Dodge trucks with the standard fuel tank module from 94-04.
3/8" and 1/2" pushlock pump supply connections
5/16" OEM Dorman type male quick connect return connection
3/8" / 1/2" Multi-Barb supply pump return connection for a regulated return system (FASS, AirDog)
Plug for third port if not being used.
$49.99
Draw Straw V
The DrawStraw™V allows for greater fuel volume by using 1/2" plumbing and tossing out that weak and restrictive in-tank pump. The DSV kit has a machined billet aluminum fitting that installs inside the tank module in place of the factory pump and the HF unit installs in the top of the module utilizing fewer parts than a traditional bulkhead fitting.
Another benefit is being able to use the original OEM supply connection as your FASS or AirDog return line thereby putting more fuel back into the module for low fuel level situations and no need to cut the filler neck hose.
Comes with:
DSV fitting, 1/2" draw tube, clamps, HF module fitting w/stainless washer and lock nut, push lock fitting for supply connection and instructions
This unit is for in-tank pump modules only!!!
$49.99
You choose the fuel line size your currently using which is either 1/2" or 3/8".
Old Mar 24, 2010 | 04:28 PM
FormerVendor
Order an Airdog or Raptor from us and receive an upgraded Draw Straw for 1/2 price. No more 1/4 tank fuel issues.
Old Apr 5, 2010 | 12:29 PM
FormerVendor
Old Apr 13, 2010 | 12:35 PM
FormerVendor
These make installing an Airdog or FASS alot easier and no more 1/4 tank fuel issues.
mudsmokinStroker
Ford Powerstroke 08-10 6.4L
Jun 29, 2015 02:19 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
Baradium
Nov 21, 2014 08:20 AM
Kentonjl
Sep 30, 2014 07:22 AM
