hx40 question
Old Mar 16, 2010 | 10:02 PM
tltruckparts's Avatar
Default hx40 question
ok guys i have no idea if this belongs here or not but hopefully someone can answer my question. i know the hot things for the h1c's and hx35's and stuff is the compressor wheel upgrade. does anyone know if people do that to an hx40 as well? i dont even know what size wheel is on my turbo right now and would like to look into upgrading.
its just a standard hx40 8 blade. NOT the super hx40. i would prefer not to buy a whole new turbo, but i might upgrade it depending on the price.
Old Mar 17, 2010 | 12:21 AM
ArizonaRedneck's Avatar
Selecting the best turbo for your application is a matter of choosing the right turbo for your intended power level and your intended i figured if you read this on hx40 you could figure out what you need to upgrade yours
Old Mar 17, 2010 | 01:08 AM
i didnt see anything about upgrading compressor wheel sizes or anything like that. i dont even know if people upgrade those like they do with the 35's to make like a 35/40 hybrid
Old Mar 17, 2010 | 06:53 AM
BAD ASS RAM's Avatar
if you have an 8 blade it will not move as much air as a 6 blade,and it's probably 56mm,if you go on ebay they have 6 blade 60mm wheels for the hx40,i would get one of those,they are like 80 dollars.
Old Mar 17, 2010 | 12:47 PM
will i have to machine clearance for it or do you know if itll fit stock? and how hard is it just to change the wheel. do you just pull that front bolt off and it slides right off?
Old Mar 17, 2010 | 02:44 PM
yeah just remember that nut is left handed threads!and it should clear,if not i just took a carbide burr in an air tool and opened mine up.
Old Mar 17, 2010 | 02:58 PM
Compressor Wheel Holset HX40 60.00mm Ind 86.00mm Exd : eBay Motors (item 180447193326 end time Mar-19-10 10:05:17 PDT)
is this what i need or something different? how hard was it to install it. could you do it with the turbo still on the truck or do you need the take the exhaust housing off the turbo first
Old Mar 17, 2010 | 03:35 PM
that's it,and you can do it on the truck.you're lookin at an hour -two at the most
Old Mar 17, 2010 | 03:53 PM
cool ill go ahead and order that! thanks for the help!
is that what makes it a super hx40?
Old Mar 17, 2010 | 04:22 PM
i'm not sure about that but i am sure you won't have any trouble with it,and it should whistle better!
