Oil pressure gauge actin funky
Old Mar 16, 2010 | 07:14 PM
dolmstead2007's Avatar
Default Oil pressure gauge actin funky
Okay well im kinda worried my oil pressure indicator is not workin anymore it comes up from the resting spot to the L on the gauge after about 20 seconds. Im hoping its not the pump. This is on my 88 F250 7.3 5spd.
Old Mar 16, 2010 | 10:19 PM
redneck817's Avatar
i would check the connection to the oil pressure sensor and oil level
Old Mar 16, 2010 | 11:29 PM
I forgot to say that i changed the oil bc it had been 3500 miles on it since october. I figured it might have been reading low like it usually did when it was time for a oil change. Changed it and no improvement this time. Still takes forever to come up to the L and the engine light to go out.
Old Mar 17, 2010 | 12:05 AM
ArizonaRedneck's Avatar
you could always install a mechanical gauge then you would know for sure what your oil pressure is
Old Mar 17, 2010 | 12:09 AM
Sycostang67's Avatar
You could try cleaning or replacing the sensor.
Old Mar 17, 2010 | 12:02 PM
OKay im tryin to remeber where its at if i remember correctly its in the back between the 2 heads Ive had the aircleaner and glow plug relay out recently so i coulda bumped it ill check today.
Old Mar 18, 2010 | 09:52 PM
Spurrit's Avatar
Did you check the oil? Maybe you're out!
Old Mar 19, 2010 | 09:41 PM
Okay well i fiddled with puttin a new sending unit in and then taking that back out bc it wasnt reading yet. I put mechanical gauge in still showed no pressure. Come to find out there was all kinds of gunk built up in that extension tube from the block to the sending unit. So i cleaned that tube and put it back together magicly it works again.
Old Mar 20, 2010 | 03:44 PM
Thats cool, easy fixes are the best.
Durtyd09
Nov 11, 2015 01:43 PM
jhprice
Mar 29, 2015 09:36 PM
Ruddedawg5.9
Mar 1, 2015 09:16 PM
ericthered
Jan 31, 2015 10:09 AM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
