have codes, 1492, 1693 and 0122
Old Mar 15, 2010 | 06:35 PM
saab9k's Avatar
Default have codes, 1492, 1693 and 0122
All 3 showed up on truck odometer, first round 1492 and 1693. Second round 0122 came up.
Hooked my scanner up and got a 0122 only, used my super chip scanner.
Cleared the code, have not driven it since. The check engine light have been coming and going.
So i need a new ecm ( throttle position sensor ) ??? right or wrong.
Thanks for any help.
Old Mar 15, 2010 | 09:16 PM
ArizonaRedneck's Avatar
check this out and see if it will help solve your problems https://www.dieselbombers.com/24-val...ode-p0122.html hope it helps
Old Mar 16, 2010 | 07:10 PM
saab9k's Avatar
thanks, will check it out, printed and saved all the info.
Old Mar 22, 2010 | 08:45 PM
saab9k's Avatar
cleared the 0122 code, now these 2 is left
P1492 Ambient/Batt Temp Sen Volts Too
High
External temperature sensor input above acceptable
voltage.
P1693 (M) DTC Detected in Companion Module A fault has been generated in the companion engine
control module.
P1693 (M) DTC Detected in PCM/ECM or DTC
Detected in ECM
A 9Companion DTC9 was set in both the ECM and PCM
