Compound with a stock HX35?
Old Mar 15, 2010 | 01:07 AM
justinb12's Avatar
Default Compound with a stock HX35?
Can you compound with your stock turbo? if so what would be a good one to use? And if not what would hold you up?
Old Mar 15, 2010 | 01:11 AM
tltruckparts's Avatar
alot of people run an hx35/ht3b combo. upgrades after that go to like an s300/ht3b or hx40/ht3b combo. ht3b's are often swapped out to s400 or s480's or sometimes hx60's as well. but the ht3b is the most common large turbo used
Old Mar 15, 2010 | 01:12 AM
justinb12's Avatar
and thats like what a grand for turbo and pipe'n?
Old Mar 15, 2010 | 01:47 AM
Source Automotive sells a kit. - http://www.sourceautomotive.biz/shop/index.php
Old Mar 15, 2010 | 02:07 AM
if it was alot more people would do it. your looking at 2 to 3 times that. a decent large turbo will run you anywhere from 700-1200 bucks.
the absolute cheapest piping period i have found is like 1200. most kits for just piping run 2000 on up
doing it really cheap your lookin at around 2k or so
Old Mar 15, 2010 | 02:13 AM
justinb12's Avatar
thats not that bad. I was thinking that there was a surplus of ht3b or s300's cuz it was on something from factory. I was mistaken, but the power gain most be good for that kinda bread right??
Old Mar 15, 2010 | 02:19 AM
you can find used ht3b they came off big rig semis but theyre pretty hard to come by. s300's are mostly all aftermarket and cost a pretty penny as well. but it is a very nice upgrade
Old Mar 15, 2010 | 04:31 AM
We also a source to get everything needed to add a turbo to your HX35. Our kit also makes it easy to replace your HX35 down the road with something like a 62mm or 64mm turbo.
Old Mar 15, 2010 | 06:59 AM
Diesel Dummy's Avatar
I now have a set on mine with a stocker over 3B, works good and 600hp can be had out of a set, but mainly they are good for daily driver and towing.
Old Apr 7, 2010 | 11:35 PM
ole smokey's Avatar
if you look around you can find a good used ht3b for around 500 bucks and if you can do fab work you can get the kit built for about a grand if not less. i did a set for my brother for his birthday and i only had 780 into the kit from start to finish.
