pump head
Old Mar 15, 2010 | 12:56 AM
jim.waters's Avatar
Default pump head
is anyone on here running the 14mm pump head and 4mm bigger cam plate? what are the street manners of a truck built like that
Old Mar 15, 2010 | 02:16 AM
ArizonaRedneck's Avatar
https://www.dieselbombers.com/5-9l-r...ve-p-pump.html check this thread out and see if you can use any of the info in it to help you
Old Mar 15, 2010 | 04:46 PM
RSWORDS's Avatar
Most recomend not running them together, it will lock up your pump.
All teh 500+ HP trucks are running a 14mm Head and rotor.
Old Mar 15, 2010 | 07:54 PM
seandonato73's Avatar
yeah they don't seem to have a good rep for reliablilty.... was looking into it till i found out the pumps become very unreliable, better off with a p-pump if ya wanna go over 500hp
Old Mar 15, 2010 | 08:22 PM
RSWORDS's Avatar
Lots of people having good luck with a quility 14mm head. When they address the fuel supply and pump cooling they can be daily drivin.
Plus a 500hp VE has better street manors then a 500hp P-pump.... But that only matters if your looking for a DD.
Old Mar 16, 2010 | 05:30 PM
jmono33's Avatar
Does anyone know who sells good quality 14mm heads?
Old Mar 17, 2010 | 06:32 PM
rocken teck
RSWORDS are they just running the head or the cam plate and the head? i would still like to swap to a 14mm head. but there too i want a DD so i don't want any problems
Old Mar 17, 2010 | 07:43 PM
RSWORDS's Avatar
rocken teck
KTA makes the only reliable head, You can find him on 1stgen.org, the Rocken Texk seem to be hit and miss. Some say great things, some say bad things. In reality you dont even need to think about it until you get to 450+ HP. There is SO much other stuff you need to do to be able to run a 14mm head and rotar.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
Adam65
Jan 9, 2015 11:50 PM
