215 Injectors
Old Mar 14, 2010 | 03:46 AM
TXHC's Avatar
Default 215 Injectors
What's the deal with putting 215 injectors into a 160 truck? How much power increase? Do they slip right in place of the stock 160 injectors? How much power increase? How are EGT's affected? Would I need to change delivery valves also?
I'm not trying to make gobs of power, but I'd like to wake this truck up. I figure a good set of 215 Injectors, #100 Plate, GSK, HX35/14cm2-WG, 4" DP & Straight Pipe ought to set me in the right direction without getting too serious. I have the 47RH, but I plan to build one to handle serious power before I do any of the above modifications.
Old Mar 14, 2010 | 09:51 AM
94 12valve's Avatar
yes they slip right in place of the 160 injectors, no you do not need to swap DV's.
The 215 injector is a 5x .010 as opposed to your 160 injectors 5x .009.
Old Mar 14, 2010 | 11:29 AM
FastCR's Avatar
Its not a huge power difference but it is there. It was the difference between my stock clutch holding in 3rd gear and slipping with no plate and the wastegate closed.
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
