turbo housing for hx35
Old Mar 13, 2010 | 10:59 PM
bowtech's Avatar
Default turbo housing for hx35
would a 14mm non waste gated housing be a good swap? i have a stock turbo on my 94 cummins with a boost elbow. what you guys think
Old Mar 13, 2010 | 11:22 PM
Hammer's Avatar
Here you go son,read this maybe it will enlighten you a bit on some things........
TDR Website
Old Mar 13, 2010 | 11:30 PM
tltruckparts's Avatar
well with your sig it looks like you got plenty of fuel to move that extra air and turn it into power. if you ever need to make it wastegated, an external wastegate is always an option
Old Mar 14, 2010 | 03:17 AM
TXHC's Avatar
You have a stock WH1C or Stock HX35? The WH1C was on 94's.
The 14cm2 housing is a good housing for a mildly modified truck. A 16 might be too laggy, a 12 too hot. It all depends on your setup. I'd bet that a 14 would be good for yours.
Old Mar 14, 2010 | 10:28 AM
bowtech's Avatar
wat ever is on the 94 stock. so that would be good to swap out it might just br a lil more lag?would it be good like it is or wood i have to waste gate it?
Old Mar 14, 2010 | 02:56 PM
95cumminsguy's Avatar
What end result are you looking for?
Old Mar 14, 2010 | 04:42 PM
bowtech's Avatar
what would it do with the egts and boost numbers?
Old Mar 14, 2010 | 11:13 PM
A stock 94 WH1C has a 12cm housing stock, A bigger housing should help cool your EGTs because they reduce back pressure it wont do anything for your boost though you gotta change the compressor to get more air flow if thats what you want check out gillettediesel.com their a shop out here that offers bigger compressor upgrades for a couple hundered bucks they also offer exhaust housings too. So you can basically build your own turbo for a hell of alot cheaper than buying one.
avatardvr
18
Aug 8, 2019 12:38 AM
sak240
Oct 1, 2015 04:07 PM
D-350 dually
Apr 11, 2015 11:38 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
