transmission?
Old Mar 12, 2010 | 11:15 PM
dieselsmoke74's Avatar
Default transmission?
i talked to my local tranny shop about rebuilding my tranny and he said every tranny he rebuilt for a dodge cummins he just did a factory rebuild and put a dacco converter in it and never had any problems...he claims the 47RE is a good transmission the torque converters are just weak....is this true? would a rebuild like this hold up?
Old Mar 12, 2010 | 11:31 PM
Farmboy 2.0's Avatar
Check into a tranny rebuild kit from bd. Its the same parts as there performance tranny but like a fifth of the price of there complete tranny. And you can get the same thing from dtt i believe. But you still need to buy a torque converter from them but your still way cheaper and will have a really good tranny that way thats will take alot of power
Old Mar 12, 2010 | 11:42 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i got a billet tranny with a triple disc dacco converter
Old Mar 12, 2010 | 11:55 PM
http://www.shopatron.com/products/ca...57260.2114.0.0. Heres is bd link for there kits with prices.
Check goerend they might have a rebuild kit as well
My brother went the way your talking 2 years ago and now he need a new tranny again. Not saying this will happen to you but kits like bd's will be a better route in the long run. In my opinon. Spend alittle more money now and you wont have to fix it later.
Last edited by Farmboy 2.0; Mar 12, 2010 at 11:55 PM. Reason: Automerged Doublepost
Old Mar 13, 2010 | 10:59 AM
01quadcab's Avatar
I would go for more than stock with a converter. Upgrade to the red altos get a suncoast valve body and a good converter. If your planning on abusing the trans get an billet input at minimum. They are a good trans when properly built.
Old Mar 13, 2010 | 01:23 PM
I personally would do a Suncoast Extreme Rebuild Kit, Suncoast Triple Disc Converter and Suncoast Valve Body.
Old Mar 14, 2010 | 05:55 PM
lobsterman04's Avatar
I wish i did that the first time. Now i dont agree with the altos and kolenes being necessary. But the convertor, valve body, and other internals NEED TO BE UPGRADED!!!!
Old Mar 14, 2010 | 08:29 PM
turbo20psi's Avatar
#K47. Fits 1994 - 2002 Dodge diesel and V10 transmissions. Turn your 47RH / 47RE transmission into our level 3 Extreme Duty Mega Viper transmission with this Combo Kit and receive a large discount for buying in quantity. You get the Alto Red Eagle master rebuild kit with a direct 5 clutch Power Pack and Kolene steels, extreme duty brass impregnated carbon fiber flex band, Fairbanks TransAction kit, billet triple clutch torque converter (#8DXX), performance 3-4 accumulator spring, heavy duty Sonnax low / reverse servo, Sonnax heavy duty / no leak intermediate servo cover, Mopar 5 to 1 ratio intermediate servo band lever, full time torque converter fluid feed valve, Mega Spring for more holding power in 1st - 2nd and 3rd, Superior heavy duty intermediate band apply strut. Regular Price $1794.00, Extreme Duty Combo Kit Price $1591.00, you save11.3%.
Add the Sonnax billet input shaft to the #K47 Combo Kit for $671.00.
We put this kit in a 47rh,and put it in to a first gen.It runs great a little bit of bugs at first,all smooth now.http://www.transmissioncenter.net/do...FSZo5QodsHT0Vw
Old Mar 14, 2010 | 11:30 PM
01quadcab's Avatar
The cost between altos and stock is less than $20
Old Mar 15, 2010 | 03:47 PM
01trailerpuller's Avatar
I did the BD uprgrade to include Billet flexplate, billet input shaft, billet triple disk TC, VB, Double deep pan and HD clutches for $6500 installed with the shipping of the parts. Buddy of mine did just a normal rebuild with a just a HD TC and had rebuild it 18 months later had to rebuild it again. The first one cost him $4400 with the TC, the second cost him $5000 because he did the full upgrade to match the TC. I have driven 1500 miles at 70mph+ at 27780lbs GVW and never got past 170deg even in the mountains. I love this trans.
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
