12 valve fuel pressure?
Old Mar 10, 2010 | 08:31 PM
bws_86's Avatar
Default 12 valve fuel pressure?
What is the best fuel pressure to run on my truck? See add ons below, stock turbo.
Old Mar 15, 2010 | 01:02 AM
I think youd probably want 35 psi. What kind of psi is your Airdog capable of?
Old Mar 15, 2010 | 11:23 AM
94 12valve's Avatar
the air dog 150 for a 12v is set @ 30 psi.
you can order an upgraded spring that will boost fuel press to 40 psi but It will not make much of a difference in your case.
Old Mar 15, 2010 | 09:04 PM
bws_86's Avatar
When i put my air dog on they said it was 30 psi but when i checked it it was 12 psi and all of the way up was 35. I backed it down cause all of the way up it smoked alot and had a lot of turbo lag. Now that its back down to 30 it dont smoke but i dont think it runs the way it should.
Old Mar 16, 2010 | 07:55 AM
Hammer's Avatar
Hmmmm...
We just chatted about this on another thread somehwere else.
30psi is fine and will do what you want.
I run 50psi with my FASS and from what it used to be at 24psi to 50psi there was no power gained at all on the dyno.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
