Air Dog 150 Install Pics
Old Mar 10, 2010 | 07:54 PM
cummins602's Avatar
Default Air Dog 150 Install Pics
I took some pics of my installation of my Air Dog 150. I kept the captions at easy to under stand. I thought these were the important parts of the install. Hope this helps some of you. Enjoy
Attached Thumbnails Air Dog 150 Install Pics-air-dog-mounting.jpg   Air Dog 150 Install Pics-fittings-1.jpg   Air Dog 150 Install Pics-sending-unit.jpg   Air Dog 150 Install Pics-tapped-hole.jpg   Air Dog 150 Install Pics-together.jpg
Air Dog 150 Install Pics-basket.jpg   Air Dog 150 Install Pics-straw-fitting.jpg   Air Dog 150 Install Pics-straw-tank-1.jpg   Air Dog 150 Install Pics-2010-03-07-22.07.02.jpg
Old Mar 10, 2010 | 08:09 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
good job
Old Mar 10, 2010 | 08:30 PM
cummins602's Avatar
Thank you... and thank you for the Air Dog
Old Mar 10, 2010 | 08:46 PM
diesel pap's Avatar
your welcome
Old Mar 11, 2010 | 06:52 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
I see you added an elbow to tie in your fuel pressure gauge... My truck had one from prior owner and my mechanical line isnt long enough to reach anywhere else... However AirDog provides a port FOR fuel pressure. Its on the pump housing itself... Why didnt you run the sending unit there?
Old Mar 11, 2010 | 06:59 PM
Jet A Fuel's Avatar
Nice pics, thanks for taking the time to post them.
Old Mar 11, 2010 | 07:31 PM
92typhoon937's Avatar
nice
Old Mar 13, 2010 | 05:38 AM
cummins602's Avatar
I am savinv that port for the dummy indicator light. Have to order it from air dog.
Old Mar 13, 2010 | 09:37 AM
Just curious, why use the light if you have the gauge? Just as a emergency backup?
I planed on using it for the fuel pressure gauge on my Adrenaline w/ pulse... Then I can take advantage of its alarm features.
Old Mar 13, 2010 | 10:13 AM
cummins602's Avatar
Yes.... its a big helper if your gauge quits working. If your filter or God forbid the Air Dog quits working, the light will come on. Usually the filter is plugged and will need changed. This is an indicator that you should not be unning your truck, I learned that lesson last year.
