delievery valves
Old Mar 10, 2010 | 04:45 PM
bowtech's Avatar
Default delievery valves
whats the difference of fuel flow between the 131 ad the 181 and all of those? what the power difference?
Old Mar 10, 2010 | 05:28 PM
Red_Rattler's Avatar
High Tech Redneck
When I get on the pc I have a pic showing the diff between 131 181 191 and full cut. As for power it's a crap shoot sure full cuts flow more but a properly tuned pump with 181s can make more power than full cuts thrown into the pump. It's all in the tuning of your pump for sure.
Old Mar 10, 2010 | 05:32 PM
bowtech's Avatar
bc im throwing in some 181s in my 94 upgrade from the 131 and i got a set of 215 injectors whats the best thing to tune for the pump? do i need some orings or some thin when i replace the dv?
Old Mar 10, 2010 | 08:42 PM
wes-cummins's Avatar
i think you need copper washers, truck should make pretty good power with 181s
Old Mar 10, 2010 | 10:22 PM
High Tech Redneck
Well it's def alil more involved but worth it if your tryin to get fuel.... It involves takin the pump off and getting it benched and gettin the barrels turned. But it yeilds some crazy fuel. While it's on the bench to you can get the pump balanced. Anyways these figures are from a stock 180hp pump. Stock plate with stock barrels was 171cc. Stock plate with turned barrels was 190cc. 100 plate in stock position with turned barrels was 326cc. 100 plate full forward with turned barrels was 445cc. Just so you know 500-550cc's is enough fuel to support 600hp.
Old Mar 11, 2010 | 10:35 PM
95cumminsguy's Avatar
I agree playing with your p pump beyond fuel plates and DV's has its benefits. But it depends on what you want the truck to do if you wanna race, pull sleds then go wild get your barrels turned but if all your looking for is a decent street truck thats reliable and you can still tow with it I would just leave it alone once you start getting into the 300 cc fuel range it takes alot of air to take avantage of that much fuel and even at that your EGT's are high. Also you can take the life expectancy of you engine a chop it in half, I dont care what anybody says nothing is reliable above 500 HP thats 3 times the factory HP on a 12 valve
Old Mar 11, 2010 | 10:53 PM
lodal cummins's Avatar
so what dv's are in the 180 pump?
Old Mar 11, 2010 | 10:59 PM
Im almost 100 % sure a stock 180 pump has 181's
Old Mar 12, 2010 | 05:56 AM
94 12valve's Avatar
stock 180 pump should have 181dv's in it
Old Mar 12, 2010 | 10:08 AM
Smokem's Avatar
Do not use the copper/steel seals below the seats with the 181's, take them out.
