injectors
Old Mar 9, 2010 | 09:31 PM
1stGen1990's Avatar
Default injectors
I know you guys prolly get this question alot, but here it is again. I am overhauling my 12v cummins right now and was wanting to get opinions on what performance injectors to get that give you the most power for your money, good and bad experiences with the injectors you have, anything like that. #3 injector went bad on mine and the piston was toast. So anything will help. Thanks guys!
Old Mar 9, 2010 | 10:32 PM
stackx2's Avatar
dont buy POD's they are a realy smokey injector,will lower your fuel milage, and raise your egt's. some very good performance injectors are the DDP40's. good milage,good power, egt's stay in check slower, and are clean burning
Old Mar 9, 2010 | 10:45 PM
dieseldawg's Avatar
acutally pods would not be too bad for his truck because they have the correct spray pattern for the non ic trucks
but they wouldnt be much of an upgrade as the stock non ic injectors are almost as large
ddp4s are great injectors at a great price!! but well worth the money!!
i would just get ddp4 nozzles and have a injection shop change out your old nozzles
Old Mar 9, 2010 | 11:02 PM
tltruckparts's Avatar
SDX injectors. theyre a sponsor on here. make GREAT power, very smooth and little to no haze at idle
Old Mar 10, 2010 | 08:27 AM
kieron_kohlmann's Avatar
Call SDX and talk to them. Good folk there
Old Mar 10, 2010 | 09:40 AM
mkriebs's Avatar
Quick question regarding this. I have a Wh1c on my truck (not sure if its much larger than the H1c), I am a non IC'd truck, would it be wise for me to get injectors, or can my stockers handle it well?
Old Mar 10, 2010 | 12:25 PM
stackx2's Avatar
you can get pretty good power out of you stock injectors, my buddy put down 247hp with stack injectors and a wh1c
Old Mar 10, 2010 | 01:42 PM
the only difference between an h1c and a wh1c is that its wastegated IIRC.
Old Mar 10, 2010 | 01:54 PM
big bad diesel 416's Avatar
Site Sponsor
iam low-mid 400hp with stock sticks and turbo
RSWORDS's Avatar
POD's are not much of an improvement over stock. They are not really that much larger and you probably wont tell adifference between them and a good set of stockers.
