ksb spacer??
Old Mar 9, 2010 | 08:39 PM
nborga87's Avatar
Default ksb spacer??
someone over at compd told me that there is someone on here that has a ksb spacer that gets like 10 more degrees of timin out of the ve pump. anybody know what im talkin bout?
thanks
nick
Old Mar 9, 2010 | 09:01 PM
DieselPerformanceGuy's Avatar
yea i think it is alwaysworking at M&H ink.
stillcummin's Avatar
you actually want to remove some shime to advance timing quiker or go to a lighter spring
Old Mar 9, 2010 | 09:17 PM
nborga87's Avatar
M&H ink what is that? also i see you have the 3 in. cooler tubz in your signature how much did they affect your performance and are you running the stock intercooler with them?
Old Mar 9, 2010 | 09:28 PM
riesenbr549's Avatar
looking inside the pump a guy could probabbly take the spring clear out that would rotate the cam plate to full advance witch is ??? Depends on pump timing for total advance. i was thinking the internal advance was only 4-6° ? not sure will have to do some digging.. On a note thou removing the spring may cause harder starting and white smoke as you will disable the variable pump timing altogether.
Old Mar 9, 2010 | 09:33 PM
nborga87's Avatar
what would the total advance be with the spring completely out?
Old Mar 9, 2010 | 10:23 PM
tower_ofpower's Avatar
i'd just get the spacer, and use the shim provided... it works just fine the way M&H designed it i spent 230 bucks with M&H and its been the best investment in my pump so far.
Old Mar 9, 2010 | 10:33 PM
nborga87's Avatar
what is m&h s website having trouble finding it or phone number?
Old Mar 9, 2010 | 11:08 PM
tltruckparts's Avatar
they are a sponsor on here go to the sponsor page and you should be able to find all there info!
Old Mar 10, 2010 | 12:50 AM
pewder's Avatar
M&H Inc. - Diesel Bombers
