3 bolts on AFC
Old Mar 9, 2010 | 06:56 PM
ztk7220's Avatar
Default 3 bolts on AFC
I have herd of people just breaking off the tamper proof bolt and running with three bolts just wondering if this is safe
Old Mar 9, 2010 | 07:08 PM
mylilpwny's Avatar
im running that and have had no problems for 2 months now .. but thats just my experiance ... planing on getting 4 bolts and replacing them all to be the same to make it easier ... just make sure they are tight
Old Mar 9, 2010 | 07:23 PM
zach_west's Avatar
i've always ran 3 bolts i don't think it hurts anything at all.
Old Mar 9, 2010 | 09:21 PM
R&RDiesel's Avatar
FormerVendor
We haved worked on a lot of trucks with only 3 bolts, and have apeared to have no problems, we like to put 4 bolts in, but thats just us, i dont see a problem with running 3 bolts if you have too, just make sure they are pretty snug like stated above.
Old Mar 10, 2010 | 07:09 AM
85_305's Avatar
Being Evaluated
Whats the easiest way to break off the bolt?
Old Mar 10, 2010 | 08:20 AM
HAYMAFIA's Avatar
i always use a small punch and just tap the edges til the sucker breaks loose and twist it out with ur fingers. or if you can get to it get a very sharp chisel and hit it rite in the center and then use a flat head screwdriver to spin it out
Old Mar 10, 2010 | 10:38 AM
85_305's Avatar
Being Evaluated
Ya I'm thinking about chiselling a line into it the back it out, but if there isn't an issue w/ running no screw in there I might just hack the head off. Or by tapping the edges will the entire screw be able to back out of the hole?
Old Mar 10, 2010 | 11:05 AM
zach_west's Avatar
i hit it with a chisel and it broke completely off. if you were going to do that i'd just replace it.
Old Mar 10, 2010 | 11:06 AM
85_305's Avatar
Being Evaluated
I may just do that.. screw messing around with trying to indent it then backing it out
Old Mar 10, 2010 | 11:08 AM
94 12valve's Avatar
I have 2 holding the shutoff and 1 on the rear slot. It makes plate changes and afc adjusting very easy
