Timing Trouble
Old Mar 9, 2010 | 03:15 PM
KoalRolr's Avatar
Default Timing Trouble
Timing keeps slipping. Its held for 6 months then I adjusted it for new turbo and it wont hold, I've torqued to 155ft-lbs the first 2 times it slipped and this time I torqued to around 170-175ft-lbs and I think it slipped again on saturday. Haven't got to check it for sure yet but I think it did.
Anyone know what I could do to get it to hold timing??
Old Mar 9, 2010 | 03:19 PM
94 12valve's Avatar
clean the shaft and gear with electrical contact cleaner and make sure there both very very clean before reinstalling
Old Mar 9, 2010 | 03:25 PM
KoalRolr's Avatar
Alright i'll try that. Is it possible to pull or stretch the threads on the nut, cuz they seem to be pretty mean deep threads? I;ve replaced the lock washer cause mine was completely flat and doing no good.
Old Mar 9, 2010 | 10:19 PM
HAYMAFIA's Avatar
try a new nut if you have it on and off alot
Old Mar 10, 2010 | 11:03 AM
94 12valve's Avatar
yes you can stretch the threads on the nut. If you think yours may be then buy a new nut there 8 bucks, its way better than stripping the threads off the nut while on the shaft.
Old Mar 10, 2010 | 01:56 PM
KoalRolr's Avatar
Just checked the timing and its still perfect no slip or anything. Long crank before finally starting it kinda pops thru the intake I thought it might be a stuck valve or push rod broke pulled valve covers and started it again and everything is working perfect.
Would a bad overflow valve on the pump cause this to happen??
Old Mar 10, 2010 | 02:29 PM
94 12valve's Avatar
have you checked your injectors?
Old Mar 10, 2010 | 06:31 PM
KoalRolr's Avatar
No sir i haven't i'm gonna check fuel pressure in the morning if i can find the right shrater valve. I just had my DDP injectors rebuilt 7 months ago cause one stuck open not that that means theres nothing wrong there.
To check my injectors just pull them and do a pop test correct??
Old Mar 11, 2010 | 05:58 AM
94 12valve's Avatar
yes a good pop test, what timing is your pump set at?
Old Mar 11, 2010 | 01:32 PM
KoalRolr's Avatar
I got it set at 6mm of lift and its a '98 215hp pump so its almost to 19* if the info I got was correct. Didn't get injectors or fuel pressure checked yet gonna try a overflow valve out of my buddies truck to see if that might help it?
