Timing slip
Old Mar 9, 2010 | 09:39 AM
joey's Avatar
Default Timing slip
Ok how does the timing slip and how do i keep it from doing this. Is it from not tourquing the nut enof or do they just slip because my truck used to get like 20 and now in 6 months its getting 13 and i dont have that much done to the pump.
Old Mar 9, 2010 | 11:05 AM
94 12valve's Avatar
the gear is a tapered fit so the shaft and gear must be super clean when timing is set. Cummins says to torque the gear nut to 144ft/lbs, Most my self included torque the nut to 155ft/lbs to help prevent slipping.
Old Mar 9, 2010 | 11:50 AM
85_305's Avatar
Being Evaluated
How many miles have to be stacked on a stock truck generally for the timing to slip?
Old Mar 9, 2010 | 11:51 AM
Whit's Avatar
Site Mascot
also make sure the shaft and the gear is clean of oil, spray them down good with brake cleaner or lectramotive spray befor you install
Old Mar 9, 2010 | 03:07 PM
94 12valve's Avatar
I have found that electrical contact cleaner work the best
Old Mar 9, 2010 | 07:36 PM
joey's Avatar
Ok well i am about to do the timing here quickly were can i get the delivery valve washer.
Old Mar 9, 2010 | 08:35 PM
KoalRolr's Avatar
When I did my timing before I got my pump sent off and built I just reused the washer and didn't have any troubles.
Old Mar 9, 2010 | 09:10 PM
R&RDiesel's Avatar
FormerVendor
It can really vary, but it wouldnt hurt to have it checked every 100,000 miles or so, not that big of a job to check it, plus it could slip a little bit and you cant really tell, can effect performance and mileage.
Old Mar 10, 2010 | 06:52 AM
85_305's Avatar
Being Evaluated
Ok thank you
Old Mar 10, 2010 | 09:35 AM
joey's Avatar
So i can reuse the washer?
