fuel pressure
Old Mar 8, 2010 | 04:35 PM
jake 94's Avatar
Default fuel pressure
With everything in my sig. what should my fuel pressure be at WOT? Its at 25-27 psi at an idle
Old Mar 8, 2010 | 05:32 PM
01quadcab's Avatar
you have a little too much pressure at idle. 20 is ideal. you don't really want under 10 at wot.
Old Mar 8, 2010 | 05:55 PM
jake 94's Avatar
The lowest i have seen at WOT is 9
Old Mar 8, 2010 | 10:43 PM
01quadcab's Avatar
should be fine there.
Old Mar 9, 2010 | 04:52 PM
01trailerpuller's Avatar
I would highly suggest the Airdog 2 165. You can adjust the fuel pressure. Also I have mine set at 19 and I have never seen below 15 at WOT.
Old Mar 14, 2010 | 01:35 PM
Rollin Smoke Diesel's Avatar
FormerVendor
I see a steady and constant 17 psi on mine. I can hit 15 psi at WOT.
James
RSD
Dbleo351
Nov 20, 2016 09:34 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
cummins Pride
Oct 6, 2014 11:28 AM
