Isspro Ev2
Old Mar 8, 2010 | 02:33 PM
cummins602's Avatar
Default Isspro Ev2
I installed an Air Dog 150 this past weekend and I got a Isspro EV2 fuel pressure gauge and the needle bounces between 24 and 26 at idle and when I get on it bounces between 18 and 20. Is this something to be concerned with or is this normal? Its electric and I have it tapped into a 90 fitting that's taps the vp44.
Old Mar 8, 2010 | 03:18 PM
01quadcab's Avatar
you need a snubber to help reduce the pulses that exist from the vp. you want to do this before it kills your electric pressure sender. I need to do this for mine.
Old Mar 8, 2010 | 07:33 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
To do it on the cheap you can get a needle valve and plumb it in between. I have a ghetto azz cheap gauge from Autozone... Its a baby little mechanical unit... Maybe 3/4 or 1" in dia. It works good but only goes to 15psi so the Airdog bottoms it out. However, it never fluctuated on my POS lift pump because it was such small line and it has a screen in it.
I was told that this bouncing will kill the sending unit so BE cautious! Not sure if thats the truth but better safe then sorry.
Old Mar 8, 2010 | 11:10 PM
cummins602's Avatar
Is a snubber something I can buy at the local auto store? What exactly does it look like? Is it that brass fitting with the twist **** on it?
Old Mar 11, 2010 | 05:52 PM
01quadcab's Avatar
no the snubber is from auto meter. but you can do what your talking about like this. Gauges
Old Mar 13, 2010 | 03:08 PM
cummins602's Avatar
thank you...
With the needle valve, will it constrict the flow of the diesel to the VP44?
Last edited by cummins602; Mar 13, 2010 at 03:08 PM. Reason: Automerged Doublepost
Old Mar 13, 2010 | 06:03 PM
01quadcab's Avatar
no your just dampening down the pulses to the gauge.
Old Mar 13, 2010 | 08:26 PM
You can get a snubber from Genos Garage too... Its the AutoMeter unit... Its 21$ and their part number is AM-3279
They are a Supporter on here and if you post in their forum section may have a more up to date price.. My catalog is a little older.
Old Mar 14, 2010 | 01:13 AM
01quadcab's Avatar
$21 ouch they are like 16 most places.
Old Mar 14, 2010 | 09:55 AM
cummins602's Avatar
I will check it out. Thanks guys
