S300 turbo good or bad??????
Old Mar 8, 2010 | 03:44 AM
Roughneck's Avatar
Default S300 turbo good or bad??????
found a S300 turbo the other day reasonable price wondering if it would work alright with a tweaked pump ex. denny t pin, star wheel turned, pump maxed, straight exhaust all advice is welcome thanks
Old Mar 8, 2010 | 11:20 AM
mkriebs's Avatar
I know quite a few people do it. I wish I knew a specific example so I could lead you their way, but I do not. What size S300 is it? I know the 62/65/12 has been run with those mods. You may need to look into a low pressure piston lift pump though. You can get them from Cummins.
This is the route I plan to take whenever money comes (next tax return?).
Old Mar 8, 2010 | 11:42 AM
tltruckparts's Avatar
the s300 is a very good turbo. especially if an aftermarket company has got in there and started beefin em up. if its a stock s300, id go the hx40 route instead IMO
Old Mar 8, 2010 | 08:49 PM
The_Head's Avatar
Go for it!
Old Mar 8, 2010 | 09:25 PM
muskrat's Avatar
I would say definatley go for it. An S300 has a much stronger shaft than an HX40 and is is capable of similar hp. An S300G has a 57 mm comp wheel and is a base for pretty much all the more bad-*** turbos on the market ie...
Aurora 2000 - S300G
Phat Shaft - S300 based 64mm compressor wheel
Silver Bullet - S300 based 71mm compressor wheel
HTB2 - S300 based 64mm compressor wheel
Pro Street 66 - S300 based 71mm compressor wheel
BD Super B - S300G
BD Super B Special - S300 based 64mm compressor wheel
S300....GOOD
Old Mar 8, 2010 | 10:54 PM
seandonato73's Avatar
yeah thats what i'm getten with my tax return this year 62-65-12 s300
Freezzman
Jul 6, 2015 03:01 PM
|WYG|SS
Jul 4, 2015 08:31 AM
Ian Roberts
Mar 23, 2015 12:36 AM
Alfred Bruce Millett
Dec 19, 2014 05:17 PM
