ABS and E-brake light coming on then going off
Old Mar 7, 2010 | 10:53 PM
tdiezel's Avatar
Default ABS and E-brake light coming on then going off
My emergency brake light stays on after i pull the lever to release it. Then after I drive a bit, turn the truck off, and turn it back on it stops. I haven't checked the fuses yet but something tells me my battery cables are still causing some kind of problem because of the codes it threw a couple months ago. Anyone got any ideas? There are no codes and the check engine light is not on and has not come on for quite a while.
Thanks,
Trevor
Old Mar 8, 2010 | 06:39 AM
dangerous1965's Avatar
Find the switch down by the pedal and push it in it should pop right back out when you let go! If it doesn't replace it. If that's not it I don't know.
Old Mar 8, 2010 | 12:27 PM
tdiezel's Avatar
Awesome! I will give it a shot. Thanks
Old Mar 11, 2010 | 01:35 PM
MRaynor's Avatar
My 05 did this when I was having problems with one of my batteries. New battery and it never did it again.
cjt8569
Sep 29, 2015 06:39 PM
Hawkeye O'nelove
Sep 26, 2015 05:42 PM
asajay
10
Sep 8, 2015 10:40 PM
Radioking1777
Jun 9, 2015 04:13 AM
ValleyF250
Nov 1, 2014 07:56 PM
