head studs
Old Mar 7, 2010 | 01:38 AM
tltruckparts's Avatar
Default head studs
i see headstuds from ARP on certain sites that say they fit 89-98 trucks, and on other sites it says 94-98. will 12v studs fit any 12v? or do i need to find specific studs.
and i also see it says machining on 2nd gens is mandatory to get the rockers to install. is that the case with 1st gens as well?
Old Mar 7, 2010 | 02:15 AM
cumminsblazer's Avatar
ARP is just a type of stud not a brand just letting u know
Old Mar 7, 2010 | 07:57 AM
stillcummin's Avatar
arp is a brand that sells headstuds studs as well as any other hardware youll need.It is a brand though they have a website.
Old Mar 7, 2010 | 09:17 AM
RSWORDS's Avatar
ARP is a brand of studs...
Old Mar 7, 2010 | 10:01 AM
welderboy250's Avatar
could someone please ignore the bull and just answer the guys question?
i cant say for sure because ive never done it but i cant figure out what the difference would be. the rocker block machining as well as the studs them selves should be the same. maby somebody who knows better will correct me. if nothin else you could prob call ARP directly to find out.
Old Mar 7, 2010 | 11:23 AM
mkriebs's Avatar
I am not sure about the studs, but the rocker machining is mandatory on the 1st gens too!
Old Mar 7, 2010 | 12:06 PM
is it actual manchining thats necessary? or is it something i could do with a die grinder? since rockers arent like perfectly balanced or anything im pretty sure
Old Mar 7, 2010 | 12:08 PM
mkriebs's Avatar
I am not entirely sure on that. I have the instructions in the truck, but its too cold and rainy for me to get off my **** and look
Old Mar 7, 2010 | 01:31 PM
do you have studs for your truck? if so are they the arp ones? and if they are could you get me the model number so i know what ones to order. thanks!
Old Mar 7, 2010 | 03:48 PM
stackx2's Avatar
i am pretty sure thay are the same. and yes you need to have them machined it was only 75 bucks at herboth machine shop in marysville, if you dont get a true flat surface on the rocker blocks you wont get a true reading when you torque them down because the nut on the stud will move on the uneven surface
