fuel gauge
Old Mar 6, 2010 | 10:38 PM
kayden101's Avatar
Default fuel gauge
Hello all,
Have a question...
My Fuel Gauge is acting up. tank is full, sometime it reads full, and when driving it goes to empty then to 1/4 tank and back to empty.
Is this a sending unit problem? do i gotta replace the whole sending unit or and plug issue?
Thanks
Old Mar 6, 2010 | 11:21 PM
captain_stabbin's Avatar
make sure the plugs gotta good connection!!
Old Mar 7, 2010 | 02:33 PM
440ctd's Avatar
that would be the sending unit but make sure as said above that you are getting a good connection everywhere
Old Mar 7, 2010 | 02:41 PM
bowtech's Avatar
mine does that to. where is the sending unit and witch connections do you check? is it the one on top of the tank?
Old Mar 7, 2010 | 04:25 PM
kayden101's Avatar
it would be on top of the fuel tank, but im not sure which connections, i suppose check em all would be a good idea
Old Mar 7, 2010 | 04:43 PM
R&RDiesel's Avatar
FormerVendor
Check the connection on top of the tank, make sure it is good, but we have seen a lot of these trucks act like that, we had to replace the sending unit in the tank, but i would start with the simple stuff first before you start replacing.
Old Mar 7, 2010 | 06:20 PM
zach_west's Avatar
Mine was doing this it was the connection ontop of the tank.
Old Mar 16, 2010 | 08:41 PM
kayden101's Avatar
are you able to just replace the connection on the top? i called autozone, pepboys, orielliy, and napa and was told i have to replace the whole pump and it would range anywhere from 200-400 just for the item....
btw the gauge starts working after i wiggle the wire and elbow but stops after i drive it or hit a bump
Old Mar 16, 2010 | 08:59 PM
tltruckparts's Avatar
you shouldnt have a pump in your tank anyways. you should have a lift pump on your block or something in line. it should be strictly a sending unit not a pump.
and judging by the second half of that statement, sounds like you got a wiring problem there.
get it to get a solid conneciton. if you absolutely have to, splice a wire to bypass the connector for the wire thats losing connection. that will at least tell you if thats whats really wrong with it or not
Old Mar 16, 2010 | 09:55 PM
kayden101's Avatar
ok ill give the wiring a try.... so your saying the whole unit thats inside in the fuel tank is the sending unit?
sorry am a little confuse...
thx in advance
