TRANS OIL CHANGE CAN YOU GET OIL OUT TC?? HELP
Old Mar 6, 2010 | 12:40 PM
MUSCLE1's Avatar
Default TRANS OIL CHANGE CAN YOU GET OIL OUT TC?? HELP
IAM GO TO BE PUTTING AMSOIL IN MY TRANS NEED TO FIND OUT IF THERE IS AWAY YOU CAN DRAIN THE TC OF OLD OIL?? I HAVE 70000 MILES ON TRUCK IT WAS PRE OWNED? SO IDO NOT KNOW WHEN IT WAS CHANGE LAST GETTING READY FOR TRIP THINKING OF AMSOIL IN FRONT &REAR DIF DOES THIS HELP WITH MPG IS IT WORTH IT ? FACTORY OIL IS SYNTHETIC AND THEY SAY IT WAS CHANGE 5000 MILES AGO?ANY HELP WOULD BE GREAT THANKS
Old Mar 6, 2010 | 01:21 PM
dangerous1965's Avatar
Stock NO Aftermarket YES Your best bet is to go to a quick oil change place and have them do the flush on it! As far as putting Amsoil in ask if they can load their machine with it!
Old Mar 6, 2010 | 05:11 PM
wildbill's Avatar
No flush. It'll load the cooler with crap that sat dormant in the transmission. Stick with ATF+4 cause it's synthetic for one and the Amsoil doesn't have the right friction modifiers in it.
Old Mar 6, 2010 | 05:14 PM
wildbill's Avatar
No flush. It'll load the cooler with crap that sat dormant in the transmission. Stick with ATF+4 cause it's synthetic for one and the Amsoil doesn't have the right friction modifiers in it. Have the dealer do a service on it. All it entails is dropping the pan, remove the pan, adjust the one band, replace with a new filter, replace the pan, add new fluid, then adjust the other band.
Old Mar 7, 2010 | 11:20 AM
gump's Avatar
Have any information on the band adjustments for those of us wanting to do this stuff at home?
Old Mar 7, 2010 | 02:35 PM
00' Quad Cab's Avatar
I totally agree with the no flush, keep a long story short 2 flushes, 2 lost trans. within 6,000miles. Both on Dodge trucks.
IMHO the best way to do a service is to drain the pan, change the filter and adjust the bands.
wlofton
11
Jun 26, 2018 08:58 AM
PA 24valve
Aug 31, 2015 07:39 PM
ctjkelley
Jun 3, 2015 06:01 AM
J_stout
Feb 21, 2015 11:40 PM
Bigredpowerstroke
Dec 19, 2014 05:18 PM
