HOW DO I MAKE MY EGR GO MIA
Old Mar 6, 2010 | 12:18 AM
MUSCLE1's Avatar
Default HOW DO I MAKE MY EGR GO MIA
WHAT DO I NEED TO DO OR IS THERE A KIT? I HAVE 04.5 THE CAT IS FLANGED THANKS FOR THE HELP ONE MORE THING IS THERE A PROGRAMER THAT BACKS ITS SELF OFF IT THE EGT OR SOMETHING STARTS TO GO WRONG OR TO HIGH??? ANY IN PUT WOULD BE GREAT THANKS LOOKING FOR BETTER MPG?
Old Mar 6, 2010 | 07:46 AM
dangerous1965's Avatar
First off what state are you in? Sounds like CA If so be carefull full diesel inspection is right around the corner! If not just make a plate!
Old Apr 25, 2010 | 02:48 PM
quick03cummins's Avatar
take the cat off hollow it out and put it back on. no way to tell its empty.
Old Apr 25, 2010 | 08:18 PM
steved's Avatar
You stated EGR...then 04.5...then cat.
The 04.5 doesn't have an EGR that I know of...it was 48 state compliant. The cat on the 04.5 isn't flanged either.
Can you add some details to what you are wanting to do??
Old Apr 25, 2010 | 08:32 PM
Red_Rattler's Avatar
High Tech Redneck
There's no real parts to take off like the old 12v or new 6.7's. To eliminate the egr on 04.5 And up requires installing a new aftermarket cam which will run you around 500 bucks and then whatever a shop would charge you to install it if you can't do it youself. The cost involved vs what you benifit from it isn't really worth it. Some have seen 75* cooler egts and up to but not gaurenteed 2mpg and maybe 7 hp. You'd be better off with a good intake nice flowing exhaust and a programer IMO.
Old Apr 25, 2010 | 08:34 PM
steved's Avatar
A smarty will remove the 3rd injection event, which is the in-cylinder "EGR".
Old Apr 25, 2010 | 08:35 PM
High Tech Redneck
As for programers that defuel I know for sure Edge Juice with Attitude will defuel at your preset and Banks will too. I have personal experience with those two can't say about others.
Old Apr 25, 2010 | 08:39 PM
High Tech Redneck
As for the Smarty removing the third event, I know they were testing it but I was under the impression they didn't release that to the public due to not getting the desired results from it.
Old Apr 26, 2010 | 11:18 AM
steved's Avatar
I was told it removes the 3rd injection event. I own a Smarty Jr, and that was one of the reasons I purchased it.
Old Apr 26, 2010 | 06:24 PM
tdiezel's Avatar
You shouldn't have an EGR or a DPF on your 04.5. I know mine doesn't. EGR started with the Blue Tec diesels and the 6.7. If you have an EGR someone did something really wrong.
