5.9 timing pin flange torque spec
Old Mar 5, 2010 | 10:59 PM
chucks's Avatar
Default 5.9 timing pin flange torque spec
I have been unfortunate to have been affected by the killer dowel.I have been acummulating the parts and know how to do the job.The only info that I have not found is the torque spec for the timing pin flange.I must remove mine to install it on the replacement gear housing.Thanks
Old Mar 8, 2010 | 05:25 PM
spetersen502's Avatar
The timing pin for the cam i just oiled mine real good and just put some locktight on the two screws and you will be fine
Old Mar 8, 2010 | 05:34 PM
NadirPoint's Avatar
Yeah, not real critical. Re-assemble using practices consistent with good workmanship.
Old Mar 8, 2010 | 06:14 PM
chucks's Avatar
Thanks for the info.
chucks
