"Howling"/"Owl Call" sound when under no/little load at high RPM!?!
Old Mar 5, 2010 | 02:45 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
Default "Howling"/"Owl Call" sound when under no/little load at high RPM!?!
Since I bought my truck it has had a sound that can be best be described as an Owl hoot or low howel when cruising on freeway and letting off throttle to give little to no load on the engine... By varying the throttle position you can vary the howel's pitch. None when hard off throttle or hard on throttle.
Could it be a bad manifold gasket, bad boot, or cracked intercooler?? Those were my guesses. Since it sounds like air rushing past a storm door during a storm.
Thanks in advance guys!
Oh yeah,
Truck is a 99, auto trans. stock intake except K&N but been makin noise since before then.
Sorry, I totally put this in the wrong section... That's what I get for postin from my BB!
Last edited by DieselWeasel; Mar 5, 2010 at 02:45 PM. Reason: Automerged Doublepost
Old Mar 5, 2010 | 04:14 PM
Bosshogg's Avatar
Probably normal. Most likely due to exhaust gases howling as they pass through the turbine housing. Exhaust system design has a large effect on this.
Old Mar 5, 2010 | 05:35 PM
Oh? In that case i DO have a straight through exhaust but its made noise since before i deep sixed the muffler.
robbyS
Apr 16, 2015 02:22 PM
Dura800
Apr 7, 2015 09:46 PM
Dergeist
Jan 22, 2015 06:34 PM
dutchsupreme
Dec 18, 2014 01:44 PM
