Intake Plate
Old Mar 5, 2010 | 07:59 AM
Drothgeb's Avatar
Default Intake Plate
I took my intake plate off to see what I can do to help the air flow. As I soon as I got it off, I could see the head's design is terrible(5&6are really choked off). I'll probably try to mill out a tunnel ram when I have time. But for right now, it seems to be pretty obvious that if I rotated the stock plate end for end, that it should provide a much more even flow to all cylinders.
Have any of you that tried that? Does it make much of a difference?
Old Mar 7, 2010 | 10:01 AM
wes-cummins's Avatar
y are they choked off? did you noticed any differance by flipping it around?
Old Mar 7, 2010 | 10:04 AM
bowtech's Avatar
wat intake plate? the thing that the air horn bolts on to thats under the grid heater?
Old Mar 7, 2010 | 10:17 AM
yea im pretty sure that thats the one that he is talking about
Old Mar 7, 2010 | 10:21 AM
bowtech's Avatar
i was told that the #6 does run the hottest makes sense since its farthest from the intake
Old Mar 7, 2010 | 10:31 AM
i would think that going to a twin ram would solve this problem
Old Mar 8, 2010 | 12:42 PM
Drothgeb's Avatar
When you pull the plate off, and look inside the head's plenum. There's are large hump inside between cylinders 4&5. Looks like it's to accomodate a filter mounted to the under side of the head, but on mine it's not being used. The hump looks like it would cut the air flow in half to cylinders 5&6. On top of that, there's a sensor mounted directly above it, that looks like it would cause even more of a restriction. All that in the air flow has got to cause some uneven pressures and turbulence.
If I rotate my 12v plate 180 degrees (24v is a different plate,) then the inlet is over the hump, and the hump would likely act as more of a deflector routing the air more porportionately to the cylinders. At least that's what it looks like to me.
A tunnel ram or twin ram would solve it, but I was just wondering if anything was to be gained by just rotating the stock plate.
Old Mar 8, 2010 | 11:33 PM
bowtech's Avatar
can u just swap it around or have to rig it up bc the tube not long enough?
Old Mar 8, 2010 | 11:52 PM
Hightech_Redneck's Avatar
i know of this issue and thats why my truck has a twin ram piece on it..... i wouldnt get it for 560 bucks but i got mine in a barn.... it was in a five gallon bucket... i kinda knew what it was an offered him 50 bucks without pulling it out and he said yes..... it had everything minus the 8 bolts and a gasket... deal of a lifetime
Old Mar 9, 2010 | 12:09 AM
KoalRolr's Avatar
To rig the twin ram up do you gotte delete the grid heater or will it all swap to the new plate?? Just curious.....
