NV4500 swap
Old Mar 4, 2010 | 10:38 PM
jim.waters's Avatar
Default NV4500 swap
So here's the deal. a guy i met has an NV4500 he is wanting to trade for the automatic out of my 93 ctd. he wants to know if the automatic will bolt to his 2nd gen 12v transfercase. also, do i need to change my engine adapter plate to install the NV4500 in my 93? any help here is appreciated
Old Mar 4, 2010 | 10:45 PM
tltruckparts's Avatar
the adapter plates are different and neither would your transmission work on his 2nd gen the computer works completely different. and also your transfer cases have different spline shafts as well. his stuff would work for you but your stuff wouldnt work for him
Old Mar 5, 2010 | 02:07 PM
1SlowCTD's Avatar
When it comes to a manual transmission and putting an auto in, itll work since ur 518 has no computer and only requires toggle switches to work(Only RE transmissions require a computer to aid in shifting in stock form). Engine adapters are different but if you both swap those too ud be fine. The transfer case is the main issue you will run into, the input shafts are differnt between the NP205 and the NP241DLD or NP241DHD. But those parts can be found rather easily and are not that expensive in retrospect. Let me know if i can be of any help as we can get you the parts for the tcase. I have put a NV4500 in my 88 chevy with a NP205 so im pretty sure we can help ya out.
Old Mar 5, 2010 | 03:01 PM
Diesel Nut's Avatar
Like posted, you will have to swap engine adapter plates. Some crossmember work will be needed for both of you. You will need to install a master cylinder then adapt it the the slave for the 4500, its different than the getrag.
As for the 2nd gen, wire the center wire to 12V key hot circuit, then run the other wire to a toggle switch grounding out and he'll have OD. I hope he knows thats a non lock up transmission.
Jonrarick
Oct 25, 2016 01:32 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
DuramaxBen
Feb 6, 2015 10:32 AM
CumminsMan2.0
Dec 11, 2014 04:57 AM
Jgloveracob
Nov 16, 2014 07:27 AM
