input shaft
Old Mar 4, 2010 | 09:40 PM
94cummin12v's Avatar
Default input shaft
how much will it hold i hhave a 94 cummins fuel plate ground and moved all the way, 370 injectors and 16' degree advance and 4 k governor spring kit and in take and exhaust i but a triple disk and a suncoast vb and a alto red egale rebuild kit. and its just a every day truck
Old Mar 4, 2010 | 09:50 PM
ArizonaRedneck's Avatar
check this thread out because you might need it some day https://www.dieselbombers.com/12-val...ts-nv4500.html
Old Mar 4, 2010 | 10:21 PM
tltruckparts's Avatar
i believe hes talking about an automatic transmission. considering hes talking about a triple disc converter valve bodies etc.
i cant answer your question on how much power itll hold. but helpfully ill stop the thread from taking off on manual trannys
Old Mar 4, 2010 | 10:26 PM
oops im bad need better glasses good catch tltruckparts time to get off and catch some zz
Old Mar 5, 2010 | 02:11 PM
1SlowCTD's Avatar
your input shafts longevity is dependent on ur foot. they can break at stock HP ratings and some get lucky and they hold mid range power. If you plan on modding farther than those id recommend an input shaft but if ur just going to leave it alone you might be ok for a long time. But remember boosted launches are not stock input shafts friends.
Old Mar 5, 2010 | 04:25 PM
12valvetater's Avatar
Triple disk converters eat stock input shafts alive.
Old Mar 5, 2010 | 04:40 PM
zach_west's Avatar
i know i have a standard but i have yet to break an input shaft no matter what i do. and i do alot. but i do have a problem with third gear. just got another 300 bucks shot down for third gear.
Old Mar 5, 2010 | 09:10 PM
Well the problem is when they lock they lock hard and they lock like right now. The shock load usually cracks them and then it spreads and rips all the slpines off. They sound like a shotgun going off in the cab when it happens.
Excursion73
Sep 12, 2015 10:52 AM
morris360
Aug 5, 2015 09:25 AM
Greywolf
Feb 17, 2015 06:37 PM
ERK
Jan 23, 2015 05:03 AM
woodsman27
Dec 9, 2014 09:55 AM
