Weird idle?
Old Mar 4, 2010 | 08:18 PM
98dodgecummins's Avatar
Default Weird idle?
Its weird after i drive my truck for a while at an idle it sounds like it misses what would it be? For some reason it only sounds like its missing is whenever my fuel pressure is at 20 psi at idle that is the only time it does it but like at 18 psi it goes away?
Old Mar 4, 2010 | 08:37 PM
mainman300's Avatar
do you have bigger injectors?
Old Mar 4, 2010 | 08:49 PM
yes i have bigger injectors i have 65 hp injectors.
Old Mar 4, 2010 | 08:53 PM
mainman300's Avatar
full injectors or jammers?
Old Mar 4, 2010 | 09:10 PM
well heres the problem when i got my truck i did not ask into detail about the injectors all he said was that it has 65 hp injectors in it.
Old Mar 4, 2010 | 10:20 PM
mainman300's Avatar
if they are jammers they might not have been pop tested, this will cause idle problems. what kind of lift pump are you running?
Old Mar 5, 2010 | 07:16 AM
i am running a fass ddrp fuel pump. does 20 psi fuel pressure hurt my ip any because at idle its at 20 psi.
Old Mar 5, 2010 | 12:17 PM
mainman300's Avatar
na, most guies run 15-17psi tho. can you adjust that lift pump?
Old Mar 5, 2010 | 08:46 PM
no i dont think so?
i think i would have to do something inside the fuel pump to get it too go down?
Last edited by 98dodgecummins; Mar 5, 2010 at 08:46 PM. Reason: Automerged Doublepost
Old Mar 5, 2010 | 10:15 PM
Codgedodger's Avatar
FormerVendor
As long as it dosent go over 20psi you will be fine. And on the injector issue, It wouldn't make a difference what brand the injectors would be that effects the idle, also Edge Jammers don't make a 65hp injector so I wouldn't think that there jammers. The only reason that the injector would effect the idle is that if your spray was off and streaming or if one injector was 20bar or so off. I recommend getting your injectors pop-tested if they have more than 100k miles on them. That way you can tell if they are junk or not...
