which type of amsoil
Old Mar 4, 2010 | 06:04 PM
rsexton721's Avatar
Default which type of amsoil
im getting ready to change the oil in my truck and im going to put amsoil in it but not sure which 15w40 to get AMSOIL Premium API CJ-4 Synthetic diesel oil or the AMSOIL Synthetic Diesel & Marine Motor and what type of filter should I get i hear fleetgurds is that the one to go with
Old Mar 4, 2010 | 07:45 PM
dieseljunkie's Avatar
Looks like you have an 06 cummins... For the 06, Amsoil recommends the CI-4 Amsoil. As far as filter, I would go with the filter Amsoil offers, the EAO filters are fantastic.
Scott
Old Mar 4, 2010 | 09:26 PM
dangerous1965's Avatar
If your gonna put out the bucks for that oil do it right and get a bypass oil filter to extend the life of that oil! Look up a FS-2500 Wouldn't it be great to go 20,000 miles between oil changes!
Old Mar 5, 2010 | 03:24 PM
rsexton721's Avatar
it would be great but i dont drive my truck enough for that maybe 10000miles a year
Old Mar 5, 2010 | 03:31 PM
I think Id go with the HD Marine and Diesel 15W40
Old Mar 5, 2010 | 04:18 PM
06Dodge's Avatar
rsexton721,
Your 2006 calls for CI-4 oil not CJ-4, so your choice is either the Diesel & Marine 15w40 or if you don't have a ton of miles 5w30 HDD. As for oil filter either the Amsoil EAO-80 or the Donaldson ELF 7349. Note the Amsoil EAO-80 and Donaldson EFL are the same filter. If you have any other question head on over to the Amsoil section and ask Heath our resident Amsoil guru.
Old Mar 5, 2010 | 10:29 PM
rsexton721's Avatar
on amsoils website it recommends cj-4
does it make a difference weather it is cj-4 or ci-4?
amsoil says cj4 but i keep seeing ci4
nvm it does say ci-4 i was misreading sorry
Old Mar 5, 2010 | 10:40 PM
2500HeavyDuty's Avatar
CJ-4 is a newer up to date oil, It has every additive that the CI-4 has plus more so the CJ-4 is more then ok to run in older dieses
Old Mar 6, 2010 | 09:02 AM
Heath's Avatar
Authorized Amsoil Dealer
CJ-4 oil is required in all 07 and newer equipped with the DPF. It can be run in all diesels but is required for the newer. 06 and older can still run the CI-4+, which is our diesel and marine, the 10W-30 or the 5W-30. The diesel and marine is by far the most popular.
I'm wondering..does the 06 list 15W-40 as an oil in the manual? AMSOIL is not listing any 15W-40 in the guide and I'm guessing that is why?
Old Mar 7, 2010 | 09:15 PM
rsexton721's Avatar
not sure ill have to look in the manual i let you no
In the manual it says 15w40 if ur using a petrolium oil and 5w40 for a synthetic
