4k GSK KIT INSTALLATION?
Old Mar 4, 2010 | 01:28 PM
Threesixty's Avatar
Default 4k GSK KIT INSTALLATION?
Which is easier, the instruction I got with the kit is this:
http://www.pacbrake.com/PDF/L5658.PDF
However after searching around the internet I found another brand with different instructions:
https://www.atsdiesel.com/PDF/3000_R...Springs_A1.pdf
Now what I'm wondering is which way is easier and most reliable. I imagine lots of users here have done this installation, already. So, I guess what I'm asking is which method is better?
First set of instructions has the installation being done through what I think is an inspection type plug. The Second installation instructions seems a lot more involved. Looks to me like it's done through the top and I think it may require breaking off a screw.
Personally it seems that the first set of instructions is less involved.
Although, I like number 21 of the second set of instruction in that the first set of instructions doesn't give any troubleshooting tips.
Old Mar 4, 2010 | 03:15 PM
rkadcock's Avatar
N.M. Bombers Director
All of the governor springs that I've done, I've gone through the plug. The only problem I run into going through the plug is getting the plug to rethread but it always goes back together just takes some patience. The only time I've gone through the top was when I just wanted to tighten my springs.
Old Mar 4, 2010 | 04:03 PM
12vcummins96's Avatar
the pac brake method is the safest and easiest dont want anything in the ip
Old Mar 4, 2010 | 04:52 PM
Threesixty's Avatar
Okay, thanks.
My Dad will probably do the installation this coming, Sunday or maybe the week after.
I could have said, "help me with this", but I know I'll just end up watching him do all the work, when it's all said and done. Heh, he'll probably end up buying a kit for himself, if the results are unexpectantly, good.
Old Mar 7, 2010 | 06:07 PM
jaybuller's Avatar
did mine throuh the plug on the side of the pump. easy took about an hour or two to complete. my idle was just right were it was... guess i got lucky,,
Old Mar 7, 2010 | 06:17 PM
zach_west's Avatar
I did mine through the plug on the side took about 30 min. to do it all. ran way better. and mine's a pacbrake.
Old Mar 8, 2010 | 12:59 PM
Threesixty's Avatar
My Dad and I were talking about the installation last Sunday and he told me that a special tool (which he told me he doesn't have) was needed to turn the crank over, by hand. How did everyone else do that? Did you just use the starter to bump the crank over, is there another way or does everyone own that special tool he was talking about? ...or is he misinformed?
Old Mar 8, 2010 | 01:58 PM
zach_west's Avatar
get a 15mm socket and turn the motor by the garmonic balancer. thats what i used to turn my motor over anytime. and yes you can use a barring tool but the method i used works great.
Old Mar 8, 2010 | 02:27 PM
Pyro690's Avatar
Or a socket on the alternator nut. Barring tool is like $40 but you don't really NEED it.
Old Mar 8, 2010 | 02:31 PM
Threesixty's Avatar
Thanks.
I'll rely your responses to him.
