cost of p pumping a 24 valve?
Old Mar 4, 2010 | 08:51 AM
98dodgecummins's Avatar
Default cost of p pumping a 24 valve?
How much does it cost to p pump a 24 valve thats with buying everything probably used?
Old Mar 4, 2010 | 11:01 AM
mainman300's Avatar
ONE MILLION DOLLARS!
Old Mar 4, 2010 | 11:20 AM
More realistically - more like $2-3k or more.
Thats pretty much a guess though. I believe Sheid and/or Enterprise Engine has kits you can buy.
Old Mar 4, 2010 | 12:18 PM
connermcpherson's Avatar
just finished mine, with a 175 pump all the front plate gears, throttle, ddp dvs, 4k gsk, lines, and a Diesel Pro cam... mine was $2575. SUPER CHEAP for all that stuff. my lines are .093 mild steel. i got most my lines from Aden at GOS Performance if your lookin to do it, find the parts off a scrapped 12v. i got my parts plus pump for like $1100 so there ya go
Old Mar 4, 2010 | 01:07 PM
How do you like it? What are you using for injectors?
Theres a lot of misinformation on diesel forums saying the conversion isnt street friendly. Which just isnt true.
Old Mar 4, 2010 | 01:23 PM
mainman300's Avatar
How do you like the diesel pro cam? I just orderd one!
Old Mar 7, 2010 | 09:44 AM
cummins.1.5.3.6.2.4's Avatar
check out this months issue of dieselpower mag it has a yellow and black dewalt ford on the cover... they have an article on p-pumpin a 24valvle and how its done and how much it costs... i know haisley machine sells a conversion kit for around $1300 i think and then you gotta get a pump
Old Mar 9, 2010 | 09:43 PM
2141pete's Avatar
Once you sell the stuff you pull off it isnt that bad at all. I recommend finding a good pump and all the parts used, this will save alot of $$$. It's hard to put a cost on it because there are so many different things that can come up. I did a cam and a few other things at the same time. As far as being street friendly goes I love mine. I got lucky and did not have a tuning nightmare like some though. I put mine all together set the timing at 24*, pulled the plate out of the pump I had on, moved the AFC FF and it was perfect. I had 17 miles on my swap and got in the truck and drove it to NC 900 and some miles, daily drove it for 2 months, dynoed it, and drove it home with no problems. If anyone is close enough they are welcome to come go for a ride or look it over once it is back together. It's back in the shop for another surgurey right now.
Old Mar 9, 2010 | 09:48 PM
blkjack's Avatar
X2 I was gonna say the same thing
Old Mar 9, 2010 | 10:14 PM
2141pete's Avatar
I think Haisley's kit is alot closer to $1800-$1900
