Torque convertor lock up switch
Old Mar 4, 2010 | 07:41 AM
svt28640's Avatar
Default Torque convertor lock up switch
Alright i did this to my truck last night useing the tstproducts link. I spliced into the orang/black tracer like it says then run to toggle an grounded it. When i flip the switch Wait to start light comes on an noithing more happens. What did i do wrong? Did the jumper in the fuse box. DO i need to go under the truck And splice into the number 7 pin wire on the trans? Thanks guys.
Old Mar 4, 2010 | 07:55 AM
kingbrad89's Avatar
There are 2 similar colored wires on the harness there. Make positive sure you spliced the right one. The wire is in one of the 4 corners of that connector, i forget which one, but make sure the one you spliced is in one of the corners and not in the middle or something.
Good luck, and remember to flip that switch off when ur coming to a stop...
Old Mar 9, 2010 | 05:35 PM
svt28640's Avatar
still no luck
Old Mar 9, 2010 | 09:22 PM
MLV1234's Avatar
im getting ready to do this too.. i heard its worth it
Old Mar 22, 2010 | 10:43 PM
kingbrad89's Avatar
Its worth it... The only negative is it throws the code for the tranny solenoid saying there is a disconnect... But it wont set off the check engine light, it just gets stored in the CPU. Kinda confuses things when ur trying to figure out transmission problems like im having right now. But otherwise its nice for highway driving.
cumminspwr11
12
Oct 17, 2021 03:50 AM
rstrange1996
Sep 22, 2015 01:25 PM
Ryans71
Diesel Engine Conversions
Dec 24, 2014 08:47 AM
Cody Cain
Dec 21, 2014 06:50 PM
IslanderXJ
Dec 17, 2014 04:14 PM
