Auto to Manual Swap
Old Mar 4, 2010 | 03:38 AM
OregonCummins's Avatar
Default Auto to Manual Swap
I am Needing a parts list from anyone who has done this swap, and places where i can get alot of the parts, any help is appreciated.
Old Mar 4, 2010 | 06:05 AM
wes-cummins's Avatar
transmission, starter spacer crossmember, input shaft for t-cas, clutch, flywheel, pedal, master/ slave/
Old Mar 4, 2010 | 06:34 AM
96blackcloud's Avatar
you dont need the starter spacer unless you plan on putting a 6 speed in i swapped in the nv4500 you will need the tranny, bell housing, flywheel, clutch, pressure plate, release fork assebly, throwout bering, piolet bering, rear main seal, clutch and break petal assebly with all bushings and what not, hydro's, upgraded hydros if going with a 13" clutch, the stock manual wiring harness to splice into the truck so your nuetral safty and back up lights work, cover that goes around the colum, floor leather piece, the stick, 29 spline female input shaft for the transfer case, shorter 4 wheel drive linkage, a manual trucks front drive shaft, and custom lenghten your rear drive shaft if its a ex cab, hmm i think thats all
Old Mar 4, 2010 | 07:10 AM
monster12valve's Avatar
bosleys-754-455-6100. nv4500 swap with everything you need $2100...used parts but gaurenteed to be good.
Old Mar 4, 2010 | 09:07 AM
12valvecory's Avatar
the bosleys dill does that enclude a 5speed for that price.
Old Mar 4, 2010 | 09:18 AM
everything you need.. i did one from them a few years back it came with everything. sombody on here just did one from bosleys a couple months ago for the same price... maybe he will chime in here. it includes tranny and all other parts.. may want to invest in a dd though.
Old Mar 4, 2010 | 09:29 AM
that was me, got it from baisley auto sales in normalville PA 2120.00 out the door comes with everything but a clutch, and rear driveshaft.
Old Mar 4, 2010 | 11:46 AM
IS the anyone that sells this kind of kit around texas.
Old Mar 4, 2010 | 01:08 PM
not sure i know of a place in texas to get a nv4500 and parts for one but not sure about a kit
Old Mar 4, 2010 | 01:10 PM
try Standard Transmission & Gear or The Blumenthal Companies - Transmissions, Engines, Drivelines and all Powertrain Products (yes they do manuals)
