Transfer case
Old Mar 4, 2010 | 01:56 AM
eric91's Avatar
Default Transfer case
I found a 91 w250 with a 360 v8 and a bad tranny. i have a 91 d250 with a cummins and a 727. i want to swap my engine and tranny into the 4x4 truck. can i do this? what things should i know.
thanks in advance
Old Mar 4, 2010 | 07:43 AM
welderboy250's Avatar
the trucks with the gas engine unless they are one ton usually have dana 44 front axles. it also at best has a dana 60 rear. the 60 is kinda light but would prob work. ur diesel has a dana 70 in the rear. the dana 44 in the front however just aint hardly gonna cut it. it would prob last a little while but it aint safe. the front springs attached to the 44 def. aint gonna take it.
the 2wd 727 has the wrong tail shaft to work with a transfere case. also the t-case in that gas truck isnt gonna take it. u would need a trans and transfere case from a 1989 to 1993 dodge diesel.
to do what ur talkin about all ur really gonna use from the 4x4 truck is the frame. u would use the rear axle and engine from the diesel. would need to find a front axle(preferably the same ratio as ur rear axle so u dont have to change the gears), front springs, trans, t-case, and both drivelines. i could help u out but it looks like ur the whole way across the country.
Old Mar 4, 2010 | 12:30 PM
tltruckparts's Avatar
itd probably end up being cheaper and a heck of alot easier to sell all the stuff you have, and use that money to just buy a 4wd dodge truck
Old Mar 4, 2010 | 03:55 PM
eric91's Avatar
I was hoping to avoid using my rear axle because i have the spicer rearend with 3.07 gears. I was going to ask around and see if anyone locally like a trans shop would trade my tranny for the 4x4 version.
Old Mar 4, 2010 | 05:15 PM
like i said before its going to be way easier just to find one already done. just a front 60 alone is going to cost a very pretty penny. save yourself a bunch of headaches time and money and just get one already done. sell your 2wd one and make your money back
Old Mar 4, 2010 | 05:25 PM
LOGANSTANFORTH's Avatar
No you have a Dana 70 with 3.07 gears...
Go buy a 4x4 truck with a Cummins or find a W300 with a Dana 60 front...
Old Mar 4, 2010 | 09:46 PM
eric91's Avatar
I thought it was a spicer but it really is the same thing because spicer is owned by dana right?
Jrod89
Feb 24, 2015 09:48 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
miked2805
Oct 19, 2014 11:02 PM
steves2500diesel
Oct 14, 2014 05:36 PM
