Speedometer & Tach Problems
Old Mar 3, 2010 | 09:09 PM
Fullpull's Avatar
Default Speedometer & Tach Problems
My speedometer is off by about 7mph. and my tach is off bad. it doesnt go over 1000 rpms. Does this have to do with something in the dash or problems in themselves???
Old Mar 3, 2010 | 09:45 PM
CARP's Avatar
Probably bad sending units. Get aftermarket gauge kits for both.
Old Mar 3, 2010 | 09:55 PM
Fullpull's Avatar
where would you get the kits???
Old Mar 3, 2010 | 10:59 PM
DieselCrawler's Avatar
the tach is probly sender. get new sender for it.
speedo is hard to tell what it is
Old Mar 4, 2010 | 01:55 AM
Sycostang67's Avatar
The tach sensor is usually the culprit when the tach is malfunctioning. It's a dealer only part and will cost you $60-$80.
Do you have oversized tires? That will throw your speedometer off. I'm assuming this is on the 88 ford in your signature. The speedometer is still mechanically driven and the only way to correct it is to change the driven gear on the end of the speedometer cable.
Old Mar 4, 2010 | 06:27 PM
Fullpull's Avatar
Ill check the tires size. Ya its the 88. Thats not to bad on a tach unit. Ill try to find a gear for it.
Powerstroke36
Sep 21, 2015 08:32 PM
Big Mike 62
Aug 27, 2015 08:29 PM
tur370
May 17, 2015 04:00 PM
tur370
May 14, 2015 08:09 PM
gp98
Apr 1, 2015 07:08 AM
