need help
Old Mar 3, 2010 | 06:47 PM
g64870c's Avatar
Default need help
(1996 gmc 6.5l td) here is what is going on i went got new tires on my truck. got home fine went out later that day and my truck stopped running as if someone shut the key off. i tried starting it and it took 10 min to get it started. drove it to my daughters house and shut it off and it wouldnt start back up so i had it towed home the next week i tried starting it and it started up. so i took it 5 blocks to put gas in it and it died at the pump wouldnt start back up. talke to some local mechanics and they told me it sounded like the fuel pump driver module (pmd) bought one of those and put it on. started right up so i got in it and drove it about 1/2 mile and it died would not start back up. had it towed again. i can start it and let it idle for 2 hours and will do fine. if i get in it and drive it it dies i am new to diesels and dont know what to look for so any help would be appreciated. i am stumpped on this
Old Mar 3, 2010 | 06:55 PM
brindle_bull's Avatar
ok i dont know anything about the 6.5 gmc'c at all.....but i had a 6.9 ford and i had the exact same symptoms as your having. spent alot of money on it tryin to figure it out. long story short there was a screen in the IN fuel line where it connected to the injector pump and it was all full of ****....took it apart took the screen out, cleaned the crap out, blew the lines out and all was solved.......like i said i dont know anything about those motors just a suggestion
Old Mar 3, 2010 | 07:58 PM
Woody35's Avatar
yup it sounds like a fuel issue. you can hook up a fuel pressure gauge to the t handle near the alternator and get the truck some revs. if it drops below 0 your lift pump is either not working or you have a restriction in the fuel lines.
there is a fuel sock that is located in the fuel tank that can get clogged. sometimes gm put the gasoline sock on a diesel which is even easier to clog. check if that is clogged and also try to blow out your fuel lines. check your fuel filter too
Old Apr 8, 2010 | 05:02 PM
g64870c's Avatar
Default UPDATE
took my truck to the dealer today to have a diagnostic run. not good the lift pump is bad, and the injector pump needs replaced. made my day. especially when they told me how much. $2262.00 i can knock 500 off that price if i buy a pump from ss.diesel are they a good place to get parts from or is there another place that is better? any hoo there it is and thank you all for trying to help me with my issues.
THANK YOU DIESEL BOMBERS dont know what i would have done without all the suggestions
Old Apr 8, 2010 | 05:52 PM
2MuchJunk's Avatar
I would buy a true blue stanadyne pump not a cheaper one. I would question that the injection pump is bad. how did the truck run before it started dieing? If it was me I would get the lift pump working and see how if runs before replacing the injection pump.
Old Apr 8, 2010 | 07:49 PM
Woody35's Avatar
just go to a local parts store and ask for a 1993 lift pump. they flow more than other years. but i would compare prices first
Old Apr 12, 2010 | 04:28 PM
g64870c's Avatar
truck ran fine just up and died one day m for no reason thats where it all began but i did notice it seems like it didnt have the power a 8 cyl should have but that might just be me i dont know even pulling a trailer with a power washer and 500 gallon water tank on it it seemed like it was down on power
Old Apr 12, 2010 | 07:32 PM
Woody35's Avatar
see if you got air in the lines
Old Apr 13, 2010 | 12:51 PM
g64870c's Avatar
no air i have opened the t valve and pulled about 1 gallon out and no air just a steady stream
Old Apr 21, 2010 | 08:48 PM
metricwrench's Avatar
Make sure you get one who know those 6.5L, because guessing will cost a lot.
you should have 5 to 10 PSI fuel pressure, & 1 pint in 30 seconds.
A scanner (tech 2 ) will allow to monitor injection width & see if pump is performing as it should under load, fuel temp, timing advance.
wrench
