Oil Analysis Results....
Old Aug 30, 2007 | 09:48 PM
Buckshotmckee's Avatar
Sma't Alec!
Bomb Oil Analysis Results....
so how do these #s look? This was the 1st oil change on the new truck with Valvoline premium blue, 15w40, 5k miles on the oil. This was also with running 1 quart of 2-stroke oil per fill-up.
Iron-21
Chromium-1
Lead-2
Copper-5
Tin-0
Aluminum-5
Nickel-0
Silver-1
Silicone-13
Boron-40
Sodium-15
Magnesium-247
Calcium-2195
Barium-0
Phosphorus-1024
Zinc-1303
Molybdenum-23
Titanium-0
Vanadium-0
Potassium-0
Fuel(%vol)-<1
VIS @ 100 C cst-14.5
Water(%ofvol)-0
Soot/Solids(%wt)-0.4
Coolant-No
Old Aug 30, 2007 | 10:35 PM
dieseljunkie's Avatar
I need to take a look at what averages are, but what did it say for the oil? Did it say it was still acceptable to use at those levels? BTW, did you ever look into becoming an Amsoil dealer?
Scott
Old Aug 30, 2007 | 10:52 PM
Sma't Alec!
They said everything looked normal.
I don't have time to do the Amsoil thing. I wish.
Old Aug 31, 2007 | 06:31 AM
Heath's Avatar
Authorized Amsoil Dealer
Looks pretty clean. No TBN on this one?? That should be automatic on diesel oil but apparently it's not. If TBN were 8 or higher, I'd (IMO) go 10k on the next one
Very nice.
Old Aug 31, 2007 | 07:10 AM
Sma't Alec!
I went to Mobil 1, Delvac 5w40, when I changed the oil, and I'm going to go 10k and see how it goes.
Old Aug 31, 2007 | 08:52 AM
Whit's Avatar
Site Mascot
10k is very easy for any synthetic oil to do..........however you MUST change the filter every 5k..........this new qt of oil you do when you change the filter will help the TBN number to stay high
Old Aug 31, 2007 | 08:57 AM
Johnny Cetane's Avatar
ok here's my rookie question for the week:
what's TBN, why is it important, and what's a "good" number?
Old Aug 31, 2007 | 08:59 AM
Whit's Avatar
Site Mascot
TBN....total base number
to get yer TBN you should send in a sample of brand new oil to yer analyser guy and he will run it and give you a TBN for that oil.
most analyser dudes wont give you a TBN unless you request it.....thats dumb
Old Aug 31, 2007 | 10:51 AM
Sma't Alec!
On these newer trucks, they have a 15k oil change interval, so I think the filter should be fine.
Old Aug 31, 2007 | 11:59 AM
Whit's Avatar
Site Mascot
15K......I was unaware of that...WOW these damn trucks are gettin higher and higher milage per change than ever
one word of caution that I know and would also like more feed back on from those in the know ................is what about suspended soot particles...alot of us are adding more fuel so we end up with more soot in the oil....how is this playing out in the oil....I know I read about how the oils are designed to "suspend" that soot
