Seatbelt won't stop ding!ding!HELP!!!
Old Mar 2, 2010 | 06:05 PM
Big WORM's Avatar
Default Seatbelt won't stop ding!ding!HELP!!!
Anyone know how to turn off my seatbelt ding?(other than clicken the belt)it goes off if i'm parked and idleing> Thanks 06 ford f250
Old Mar 2, 2010 | 06:24 PM
SmokeN 12 ValvE's Avatar
Look in the owners manual, there's a section that tells you how to cut it off. Something about turning the key to the "on" position and buckling and unbuckling the belt several times.
1. Turn ignition switch to the run position
2. Wait until the safety belt warning light goes off (approx. 1 minute)
3. At a moderate speed buckle then unbuckle the seat belt 9 times ending with the unbuckled postion (must be completed within 60 seconds of completing step 2)
After step 3 is complete the safety belt warning light will illuminate for 3 seconds. If step 4 is not completed within 10 seconds of step 3, the belt minder will exit programming mode without changing status.
4. Within 10 seconds of the light turning on, at a moderate speed, buckle then unbuckle the seat belt. This will disable the beltminder feature if it is currently enabled. As confirmation, the safety belt minder light will flash 4 times per second for 3 seconds.
Last edited by SmokeN 12 ValvE; Mar 2, 2010 at 06:24 PM. Reason: Automerged Doublepost
Old Mar 2, 2010 | 07:03 PM
csdiesel's Avatar
Lift up the carpet find wires to that buckle cut and splice together, for a permanent fix
Old Mar 2, 2010 | 10:29 PM
Mdub707's Avatar
Why would you do that when you can disable the programming using the post above? You can then un-do it in case you ever sell the truck or anything as well. Different strokes I guess.
Old Mar 3, 2010 | 06:32 PM
csdiesel's Avatar
just an idea
crazycooter
Sep 22, 2015 08:43 PM
gunman41mag
The Sportsmen's Lounge
Sep 7, 2015 07:41 AM
K31TH
Apr 25, 2015 12:25 AM
jyoung3
Feb 3, 2015 12:22 PM
Dec 12, 2014 08:10 AM
