ideas on more low end
well here it goes. I have edge juice w hot unlock, edge jammer 150's, airdog df165, custom 4" exhaust, volant air intake, con ofe clutch 5speed, 3.73 gears, hx35 made 434/988 at dave smith in kellog and the same at shelly auto in spokane. Just installed super phat shaft 62/71/14 and lost most of my low end! Need ideas on getting this turbo to spool faster. Its between a cam, smarty stack, or better injectors. Does anyone have any advice? Thanks big time guies!
From what I have read, the Smarty will smartin up that bottom end, sorry for the pun
Need to tell the VP to dump more in at low RPM, the Smarty should do that. Bigger injectors, and a cam would too, but the versatility of the Smarty may be more bang for the buck.
.Need to tell the VP to dump more in at low RPM, the Smarty should do that. Bigger injectors, and a cam would too, but the versatility of the Smarty may be more bang for the buck.
smarty's the way to go, i have almost the same setup. the smarty made a bigg diff. if you decide to do the smarty 'FYI' you cant run lv6 hot unlock on the edge' stacked with the smarty' atleast on mine you can't
cool thanks smarty seems to be the easy way to go
decited to go with a cam
Boatman
Mar 20, 2015 10:00 AM
chuffysplace
5.9L 24V Performance
Dec 20, 2014 11:22 PM
